How will TPMS work with new tires?
Old Aug 22, 2010 | 07:29 PM
LeoDLion's Avatar
LeoDLion
Default How will TPMS work with new tires?
If the tire pressure monitoring system of our RX is wireless based with sensors inside the tire, what should one do if one buys a new set of tires? If it is ABS-based like some Audi and BMW which is software based, there is no problem. Anybody knows?
Or is the sensor attached to the wheels instead?
Old Aug 23, 2010 | 08:53 AM
MEP7557's Avatar
MEP7557
The sensors are inside the tires. New tires should not affect them. They usually charge for what they call a re-build kit for each one, have no idea what that consists of, other than seals.
Old Aug 23, 2010 | 09:04 AM
TurboVinny's Avatar
TurboVinny
the sensor is on the valve stem which is on the rim/wheel
Old Aug 23, 2010 | 02:10 PM
LeoDLion's Avatar
LeoDLion
How easy would it be to transfer the sensor to an aftermarket wheel?
Old Aug 24, 2010 | 05:35 AM
ziggy1's Avatar
ziggy1
I had to replace one of my front tires due to a damage in the sidewall picked up during this past winter's miserable weather. Had it done locally, tire pressure seemed to work fine and this was confirmed by the dealer when I was able to get to them and have it checked. So, no problem with tire replacement.
Nick2JZ
Apr 6, 2026 03:26 AM
mickjh
16
Dec 30, 2019 04:22 PM
elimmigran
RX - 4th Gen (2016-2022)
Oct 29, 2017 10:31 AM
warminwisc
Sep 13, 2011 04:15 PM
luca
Sep 30, 2007 06:04 PM
