2012 Rx350 Jerks/bucks into Drive
Old May 28, 2026 | 02:35 PM
nahimrx12's Avatar
nahimrx12
8th Gear
Default 2012 Rx350 Jerks/bucks into Drive
Hi guys i've had this issue for a while now, when I shift my car from park to drive the entire car shakes ("bucks") and it has me worried, its been shifting smoothly.
Old May 28, 2026 | 08:52 PM
6runner's Avatar
6runner
Could be engine or transmission mount problem.
Old May 31, 2026 | 04:39 AM
carguy75's Avatar
carguy75
Take it to an trusted high rated transmission shop in your area and let them inspect the transmission for a proper diagnostics.
The issue could be anything from a bad transmission mount like mentioned above to maybe a bad shift solenoid located in the valve body or even an bad transmission clutch pack.
All you going to get on this forum with the limited information posted is just a lot of guess work.
Old May 31, 2026 | 05:43 AM
ChattanoogaPhil's Avatar
ChattanoogaPhil
Curious... I see that back in March you asked about changing transmission fluid. No mention of transmission problems then. Was the transmission fluid changed? If so, did the transmission problems begin afterward or pre-existing?
Old May 31, 2026 | 08:17 AM
salimshah's Avatar
salimshah
25 Year Member
What is the idle speed?
Salim
Old Yesterday | 10:11 AM
nahimrx12's Avatar
nahimrx12
8th Gear
I didn't go through with the fluid change as the vehicle got in an accident the following weeks, this problem as already existing but i had no issues shifting so it was weird to me as it only does it sometimes
Old Yesterday | 10:12 AM
nahimrx12's Avatar
nahimrx12
8th Gear
Probably is and I need to check those
nahimrx12's Avatar
nahimrx12
8th Gear
around 800
Old Today | 08:29 AM
salimshah's Avatar
salimshah
25 Year Member
Originally Posted by nahimrx12
around 800
Sounds about OK 750 being the target.
Salim
twothreetwo
RX - 4th Gen (2016-2022)
Jan 18, 2025 07:56 AM
renaldonoel
Nov 23, 2024 06:44 PM
grhughes
RX - 5th Gen (2023-present)
Oct 16, 2024 11:40 PM
stratman
IS F (2008-2014)
23
Jul 5, 2012 09:45 PM
hung8852
Dec 11, 2006 03:30 PM
