HVAC issues
Old May 3, 2026 | 06:18 AM
262mbh's Avatar
262mbh
4th Gear
Default HVAC issues
Hello all
trying to figure out some issue with my 2011 Rx
1) the head unit on the dash takes a a couple of minutes to “boot” up
2) the passenger side damper stopped working
3) the ac will not turn on
-I have replaced the logic unit under the glove box
-i have check the Freon levela
-the pump is not cycling or the condenser fan not turning
i checked the control relay and it was ok
I have damper actuator coming as I believe I have separate issues
would love any ideas!!
thanks
Matt
Old May 3, 2026 | 07:15 AM
Clutchless's Avatar
Clutchless
Have you checked for codes?
Do you know if the compressor is turning on? If not, see these threads as there is a sensor in it that loses magnetism over time and then it will not turn on. A member figured out that if you place a small magnet on the flow sensor, then you can force the compressor to work again. Some found that after several months this additional magnet recharged the one in the sensor. Anyway, it is worth a shot.
I also hope you have checked your coolant level.
See post 3 here for the link https://www.clublexus.com/forums/rx-...79-advice.html
​​​​​​https://www.clublexus.com/forums/rx-...t-running.html
Old May 3, 2026 | 10:24 AM
6runner's Avatar
6runner
I would take the car to a dealership for a diagnosis.
Old May 3, 2026 | 04:37 PM
262mbh's Avatar
262mbh
4th Gear
The compressor is not starting at all.
the head unit takes about 60 seconds upon engine start.
has anybody seen this ?
Old May 4, 2026 | 06:32 AM
Clutchless's Avatar
Clutchless
First thing you need to do is get a small magnet and place it on the compressor flow sensor and hope that fixes it. You can get small magnets at Amazon, or Michaels or Home Depot
The slow boot up may not be an issue after that as long as it works.
Old May 4, 2026 | 09:45 AM
262mbh's Avatar
262mbh
4th Gear
thank you!
are you talking about the denso pressure switch?
could the damper not functioning on the passenger side cause the slow boot up?
thank you !!
Old May 5, 2026 | 04:27 AM
Clutchless's Avatar
Clutchless
The flow sensor on the compressor. Not sure what you mean by Denso pressure switch.
Read the links I posted above.
Dampers not working correctly are a separate issue from electronics not booting up. The damper is mechanical and they just wear out.
Do a search on damper for more information. They can be very difficult to repair.
khuong
Jul 9, 2021 07:00 PM
twylie
Dec 22, 2010 01:54 PM
NoLongerA13bFan
May 5, 2009 10:48 AM
