scratch fix?
Old Feb 28, 2026 | 12:32 PM
jazzgitah's Avatar
jazzgitah
Default scratch fix?
2014 rx350 purchased a month or two ago had a couple of scratches on hood. My hope of filling with touchup paint was a dismal failure. They are not on surface but not real deep. Other than body shop any idea to clean this up a little? Thanks
Old Feb 28, 2026 | 02:03 PM
Alex1989's Avatar
Alex1989
Try to pour as much paint into the scratch as possible so that when it dries, it creates a raised area. After the paint has completely dried and hardened, sand it lightly and polish it with a polishing machine.
You can carefully touch it up using a toothpick and liquid paint poured into a bottle cap, for example.
Old Feb 28, 2026 | 02:08 PM
That will take many applications of paint to make the repair level, really you need body filler. Use a credit card or similar applicator to apply the paint don't worry about extra getting on the surrounding area that will sand and polish off. Fill a bunch of times you'll get a decent result.
Old Feb 28, 2026 | 06:36 PM
6runner's Avatar
6runner
Some areas have mobile paint correction services who work at reasonable price.
Old Feb 28, 2026 | 08:28 PM
jazzgitah's Avatar
jazzgitah
watching videos about scratch repair....thx
Old Feb 28, 2026 | 08:42 PM
I start with 1500 then 2000 after that I polish. But it depends on the paint if it's soft then sanding is risky will be easy to remove the clear coat completely. 3000 is super fine it will work very slowly you'll make better progress with a product like this (you need a machine polisher).
Amazon Amazon
Old Feb 28, 2026 | 10:22 PM
GregMN's Avatar
GregMN
Do that. Then find car to practice on. Doesn't really have to be a car. Any painted metal will do.
You will learn masking, feathering, wet sanding (600, 1500, 2000), painting, clear coating, and wet sanding ( 1500, 2000, 3000 ). Then rubbing compound, polishing compound, and waxing.
By the end of your second practice piece, you may feel good enough to work on you car.
Or
Get some quotes. Ask around at an automotive paint supply store for recommendations.
jaxn1010
Automotive Care & Detailing
Aug 24, 2023 12:43 PM
rwmnau
Mar 3, 2022 07:55 PM
RicoBoy
Pacific
May 11, 2019 01:26 PM
TCKeyz
Canada
Jul 17, 2012 12:46 AM
