AC temp difference between driver & pass
Old Sep 26, 2025 | 08:24 AM
oshkalabah's Avatar
oshkalabah
Default AC temp difference between driver & pass
Good morning. Title says it all - AC temperature difference between driver & passenger. In my 2012, even with dual AC deactivated and both sides set to the same temp (ex. 68 degrees F), a thermo pen shows about 4 degrees colder on the two passenger vents versus the two driver vents. The AC is still cold, mind, and it's otherwise working fine, just experiencing a discrepancy in coldness between driver and passenger sides. Any thoughts?
Old Sep 26, 2025 | 08:51 AM
RX in NC's Avatar
RX in NC
Not unusual. Contributing factors could include the shape and length of the HVAC air ducts on either side of the cabin, potential obstructions in the air ducts, proper operation of the blend doors, etc. If you have not installed a new cabin filter lately, you may try installing a new one and see if that makes any difference.
Old Sep 26, 2025 | 08:53 AM
oshkalabah's Avatar
oshkalabah
Thanks. Should add I just replaced the cabin filter two weeks ago. Certainly is not a big problem since both blow cool air, just an interesting observation.
Old Sep 26, 2025 | 11:15 AM
Clutchless's Avatar
Clutchless
Do you have as much airflow with the new filter?
I once installed a new charcoal cabin air filter that restricted air flow so much I tossed it after a week of my wife complaining the A/C didn't work anymore. A different non charcoal filter fixed it.
Old Sep 26, 2025 | 11:16 AM
oshkalabah's Avatar
oshkalabah
No issues with air flow or pressure/volume/quantity. (I went with a mid-range filter too).
Old Sep 26, 2025 | 03:41 PM
salimshah's Avatar
salimshah
25 Year Member
The temperature of air coming out of the vent [for vehicles or even at home] is always cooler than the thermostat setting when the compressor [when cooling] is working]. Once the desired temperature is reached at thermostat the cooling stops.
The difference between the two sides is due to the fact the the cold air temperature drops as it sent through the ducts and the driver side vent is further from the evaporator/expansion valve. Also note that the in vehicles the air blower keeps running after the thermostat reaches set temp.
Salim
Old Sep 30, 2025 | 06:29 AM
lexflana's Avatar
lexflana
Suggest researching this a bit and watching some YT on it, but I had this issue on another Lexus once (but actually cool air on one side; uncooled air on the other so more exaggerated than your readings) and it was due to low refrigerant, which eventually we found a leak in the system.
Hope that yours is just how the system is designed; 4 degrees honestly is nothing but you'll want to research that it isn't the initial signs of something. We have a 2015 RX350 with no issues with AC, but I haven't measured the temp like you have.
Did something come up that made you want to measure it, or did you do it just for curiosity / informational purposes?
Old Sep 30, 2025 | 06:30 AM
lexflana's Avatar
lexflana
This makes sense.
Old Sep 30, 2025 | 06:31 AM
oshkalabah's Avatar
oshkalabah
In the high heat of the midwestern US summer, I noticed the passenger vents were slightly colder than the drivers vents. But again, both still pretty cool, just one side slightly colder than the other. Thanks.
Old Oct 1, 2025 | 01:57 AM
dwoods801's Avatar
dwoods801
Have you cleaned the interior temp sensor? You should find on the dash by the drivers right knee. I have different model than you, but it seems to be standard technology for this generation Lexus. The sensor gets full of lint and crud and what not and causes the climate control not to get a proper temp reading from side to side. See if you can find yours and clean it out, maybe you can narrow the difference
Old Oct 1, 2025 | 11:20 AM
oshkalabah's Avatar
oshkalabah
Good call - will check.
rigged87
Jul 11, 2024 06:45 AM
Mikeed123
RX - 1st Gen (1999-2003)
Jun 29, 2022 07:45 PM
hasansi
Jun 25, 2022 05:17 PM
SAID
Aug 13, 2021 01:58 PM
LouLee
Aug 2, 2015 06:52 AM
