Lexus rx350 2015 starter problem.
Old Sep 20, 2025 | 01:38 PM
  #31
FrankFl1's Avatar
FrankFl1
Originally Posted by salimshah
Once transmission is disengaged [P or N], when you turn the crank, you are fighting compression. With V6 you are not fighting compression on all 6 at the same time. It takes more than feather force, but once can overcome with deliberate steady force [it tends to become stiff and once past TDC the compression it practically flops over. [my estimate 25ft/lbs]. I have done number of T-blet changes and had no issues ever turning the crank by hand with 6-8 cylinder engine. If you remove all plugs it would be relatively easier, but not night and day difference.
I suspect your old starter was a collateral damage as it tried to turn over a locked engine and burnt out.
Important .... You may like to remove the starter, just in case the starter pinion is the proverbial monkey wrench.
Rotating the engine backwards is not recommend but if if done slowly [without causing too much stress it is ok.]
I still think the next best action is to remove both valve covers and confirm there is no issue with the chain. Once you confirm top-end is in unison with the crank, then remove all plugs and pour 1/4cup ATF into each cylinder and wait over night. Next day use try to work the the crank back and forth [yes back word with increasing force] to see if you can free the crank up.
Salim
Well i took out the new starter. And took both to the shop and tested them on the bench and they were both ok. So engine its definitly seized. Im gonna take both valve covers off and inspect. What bearings would be the culprit in this case?
Old Sep 20, 2025 | 03:12 PM
  #32
Clutchless's Avatar
Clutchless
Rod bearings are the most likely failure point. Those usually are easier to replace.
I found this information on a Lotus forum as Toyota sold them the 2GR-FE to put into their cars:
​​​​​​Upon review of the Toyota 2GR-FE Engine Manual I find statements that these are in fact forged steel components.
An extract from the Description section follows:
6. Connecting Rod and Connecting Rod Bearing
" Connecting rods that have been forged for high strength are used for weight reduction.
" Knock pins are used at the mating surfaces of the bearing caps of the connecting rod to minimize the shifting of the bearing caps during assembly.
"The connecting rods and caps are made of high-strength steel for weight reduction.
" Nutless-type plastic region tightening bolts are used on the connecting rods for a lighter design.
"An aluminum bearing is used for the connecting rod bearings.
"The connecting rod bearings are reduced in width to reduce friction.
7. Crankshaft
" A crankshaft made of forged steel, which excels in rigidity and wear resistance, is used.
" The crankshaft has 4 journals and 5 balance weights.
Old Sep 20, 2025 | 05:59 PM
  #33
FrankFl1's Avatar
FrankFl1
7. Crankshaft
Wow. Thats so weird. Lexus is supposed to be long lasting engine. I did check the engine today piston #3 seized. The rod broke the piston head and crushed the spark plug and bent and broke the valves.
Rod bearing went trough the piston head.
Spark plug smashed.
Spark plug smashed.
Valve bent. And valve gonee.
Old Sep 20, 2025 | 08:15 PM
  #34
salimshah's Avatar
salimshah
25 Year Member
Not sure how much more you want to go further/deeper into investigation, but I am curious to figure out the sequence of the failure.
Per you statements it seems the piston got separated from the rod and the rod hammered the piston such the it went higher than TDC smashing the spark plug and the valve came down [Exhaust stroke] ,, while the rod pushed the piston up. It seems the timing did not go bad.
The probability of failure is low for reliable vehicles. That still leave some folks who end up with a less than perfect vehicle. I am trolley sorry that it happened tp you.
Share your thoughts on what you plan to do next.
Salim
Old Sep 21, 2025 | 12:17 AM
  #35
Nevada's Avatar
Nevada
When inspecting vehicles with seized engines, I have found either no oil on the dipstick or clear, clean oil on the dipstick which means the customer added 4 quarts of oil after the engine seized.
With vehicles that are generally reliable, there is usually a reason why the failure occurred.
Old Sep 21, 2025 | 03:15 AM
  #36
FrankFl1's Avatar
FrankFl1
Salim
yeah i cant understad what happened either. Its so odd. Only cars i like to drive are lexus and toyotas and this has.never happened. I got a tacoma with 350k miles and no timing chain replacement. Proobably scheduling to do it soon.
  #37
FrankFl1's Avatar
FrankFl1
Well this is my sister car. She called me as soon it happened. She had te gas light on so she tought she ran out of gas.
Old Sep 21, 2025 | 03:52 AM
  #38
RX in NC's Avatar
RX in NC
How often does she check her oil? My guess is "never".
Old Sep 21, 2025 | 07:28 AM
  #39
Clutchless's Avatar
Clutchless
I suspect some very long oil change intervals when it was with some previous owners. Maybe they ran it low on oil or it had an overheating incident.
Now you have to decide whether to sell it for junk or pay for a used engine.
etmoron
Aug 9, 2006 10:26 AM
rsr405
Jul 23, 2006 08:44 AM
bsjoiner
23
Dec 10, 2004 08:43 AM
TxLexus
Apr 4, 2004 09:36 AM
