O2 replacement
Old Sep 3, 2024 | 06:52 AM
ronsbourne's Avatar
ronsbourne
3rd Gear
Default O2 replacement
The check engine light came on, it was the o2 sensor upstream, I had it replaced with a Denson, my fuel economy has dipped to below what it was a a faulty sensor! Normally my mpg is between 28 and 29, now it's 23. Any ideas?
Old Sep 3, 2024 | 06:59 AM
ronsbourne's Avatar
ronsbourne
3rd Gear
Default O2 sensor
By the way its a 2010 rx450h with 174,500 miles.
Old Sep 3, 2024 | 01:46 PM
iolmaster's Avatar
iolmaster
I assume you mean Denso not Denson. There is little chance that an O2 sensor would have that effect on your MPG. Possible, but unlikely.
Old Sep 3, 2024 | 03:00 PM
ronsbourne's Avatar
ronsbourne
3rd Gear
This sensor is also fuel, as soon as the check light came on my mpg dropped below 25. And yes denso
Old Sep 3, 2024 | 04:16 PM
Oro's Avatar
Oro
Have you checked the wheel bearings and brake calipers for sticking? Very probable cause for a drop like that, at that mileage. I would suspect that near the top of the differential diagnosis list.
Old Sep 3, 2024 | 07:08 PM
salimshah's Avatar
salimshah
25 Year Member
Keep in mind this sensor impacts the calculation of mpg. You may be getting wrong calculated value before/after. Just use the MPG as an indicator and do actual milage with actual fuel pumped in at fillup.
OMG ... actual milage is yet based on rotation of tire and not actual miles driven & actual gas consumed is yet another estimate.
Salim
Coleroad
Dec 11, 2015 05:21 AM
st1013
Jan 19, 2015 03:32 PM
dealer374
Maintenance
Nov 15, 2010 05:54 PM
