Rocking Driver Seat
Old Feb 22, 2024 | 05:40 AM
ekanson's Avatar
ekanson
9th Gear
Default Rocking Driver Seat
There are a couple threads out there about this issue (a little play in the seats) but they're quite old. Solution at the time was replacing the seat tracks.
Wanted to check to see if since then anyone has been able to fix the "broken" seats without having to replace the tracks.
Thanks in advance.
Old Feb 22, 2024 | 07:59 AM
salimshah's Avatar
salimshah
25 Year Member
imho the right approach is to determine where the movement is. It can be the case that the tracks are not fully secured to the body. If the play is between the tracks and the seat, I would make one attempt to reshape, knowing fully well that I might be needing new tracks. I would certainly place a spacer to prevent over-distortion and use vice instead of dead blows.
Salim
Old Feb 22, 2024 | 03:51 PM
ekanson's Avatar
ekanson
9th Gear
Salim
I've retightened the bolts to the body and they were on tight already. I think the movement is more pronounced on the right side of the seat. I'll take seat out when weather gets warmer and see if there's anything on the seat frame that can be tightened.
thanks.
Old Feb 22, 2024 | 04:00 PM
salimshah's Avatar
salimshah
25 Year Member
If you can, actually see the movement/play by applying force. Once you know which two surfaces have the play, you can devise a solution. Without this, your attempt(s) can end up with no change.
Salim
lesshoop
Jun 3, 2024 07:32 PM
2jzism
Nov 1, 2023 07:18 AM
Neophyte2b
Feb 14, 2021 11:24 AM
Hubs
CT 200h Model (2011-2017)
Sep 22, 2017 07:02 PM
rstreidl
May 4, 2011 10:18 AM
