drivers door light switch / Body Control Module
Old Jul 4, 2022 | 05:49 PM
Felix's Avatar
Felix
Originally Posted by matts6887
whats the easiest way to get the bcm out and will a replacement require programming? tia
I'd dia it Matt, vs throwing parts at it first.........
Old Jul 5, 2022 | 06:34 AM
matts6887's Avatar
matts6887
thing is i dont have dia equipment. so i cant really do too much.
Old Jul 5, 2022 | 06:41 AM
Margate330's Avatar
Margate330
A while back you thought maybe the Driver Door Ecu/Module may be acting up.
Can I suggest removing that component and see if things go back to normal with it unhooked?
Reason I ask is because you may have a bad door switch and stuff as mentioned above and that's totally possible but if the door module is ever suspected, this can keep the Body System "Alive".
Just throwing out some more ideas, great posts by members above already.
Old Jul 5, 2022 | 10:46 AM
DennisMik's Avatar
DennisMik
I don't think the BCM requires programming from the dealer. There a a few customer preference things that the dealer can program the BCM to do, but otherwise it is ready to go. I didn't have any problems with swapping in a junkyard one.
As far as removing/replacing the BCM, it isn't too hard. I just did a write-up on swapping the dashboard junction block that has the BCM in it.
Old Jul 5, 2022 | 12:30 PM
matts6887's Avatar
matts6887
so maybe the bad door switch is preventing the automatic headlights from turning off when double tapping the lock button as it could be connected to the bcm?
Old Jul 5, 2022 | 12:35 PM
matts6887's Avatar
matts6887
where is the driver door ecu/module?
kamlung
GX - 1st Gen (2003-2009)
Mar 9, 2020 06:37 PM
vesnyder
Jul 21, 2019 02:02 AM
Spartyon
Sep 15, 2011 08:40 AM
spxChrome
30
Sep 30, 2010 01:24 PM
lexus4ever
Maintenance
Mar 11, 2003 12:28 PM
