replacing the battery
Old Jul 19, 2021 | 09:57 AM
biff44's Avatar
biff44
Default replacing the battery
just had the battery replaced.
I made sure they were using an OBDII battery tender.
even with them using it, my windows, clock, and car radio needed reprogramming.
So if you are doing a battery replace, i recomment hooking up 12V to the actual battery cables somehow, instead of counting on the OBDII port to do the job!
(in case you never did it, to reprogram the windows, go to each one, and on its door manually take the window down all the way, then up all the way. this way the CPU "learns" where full up and full down are, and your driver side window switches will work again.)
Old Jul 19, 2021 | 06:54 PM
spinellib's Avatar
spinellib
Your radio needed reprogramming, too?
Usually the radio is able to keep its memory.
I never tried one of those OBDII power keeper things, but the reviews are mixed on them. The power keepers you stick in the cigarette lighter get even worse reviews.
Old Jul 19, 2021 | 09:24 PM
Felix's Avatar
Felix
Really no sweat to deal w/ reprograming.....Swap out the alternator & your undoing the terminals.
btw, what battery did you end up with?
Old Jul 20, 2021 | 04:11 AM
biff44's Avatar
biff44
i should be clear...it did NOT require me to enter a password. but the clock part needed reprogramming. the stations (FM) were still there.
Old Jul 20, 2021 | 04:12 AM
biff44's Avatar
biff44
interstate brand. was $209. basically replaced what had been in there for the last four years. i will look up the part number when i go outside.
Nooblex
Dec 20, 2024 12:13 PM
Jbthompson
Aug 24, 2018 10:33 AM
jpv7774
Jan 28, 2016 06:59 PM
vital
12
Sep 10, 2012 09:18 PM
Lexo350
Jan 21, 2006 04:11 PM
