vibration at 65mph or above(still present)
Old Feb 10, 2021 | 08:15 AM
matts6887's Avatar
matts6887
Default vibration at 65mph or above(still present)
I am still experiencing a slight vibration in my steering wheel at 65 or above highway speeds. Ive had a alignment done, i just had new front brake pads and rotors put on under warranty because i was getting a pulsing as i was slowing down; so those are new; i also had one tire replaced because the outer edge was worn through all the way around. then also had all 4 tires re balanced as apparently they were off a little; but even with all this being done im still getting a slight vibration at these highway speeds. Whats next? axles? carrier bearings?
Old Feb 10, 2021 | 08:34 AM
iMSQ's Avatar
iMSQ
Post a photo of your tire (including production date)
Old Feb 10, 2021 | 12:34 PM
matts6887's Avatar
matts6887
its NOT the tire that was in question. I had that REPLACED!. And the other 3 are perfectly fine. and let me rephrase; its not a vibration but a "wobbling" of the steering wheel I keep feeling and seeing at highway speeds 65 or above; its also random at times; sometimes it will happen for a short time and then go away; other times it starts up again and then does it for a long duration.
Old Feb 10, 2021 | 03:10 PM
DennisMik's Avatar
DennisMik
This may be kind of far out, but I remember watching a youtube video on the gen2 rx regarding the u-joint on the steering column. It developed wear and the steering had excessive play because of it. Try checking that out.
Old Feb 10, 2021 | 03:35 PM
matts6887's Avatar
matts6887
thanks dennis; i will have my indy shop look at that. What about axles and or bearings? any possibility there?
Old Feb 10, 2021 | 06:29 PM
DennisMik's Avatar
DennisMik
I don't think axles could cause the steering wheel to wobble. If the CV joints are wearing, that would create an out of balance situation like your tires. The axles are not involved in steering.
While wheel bearings could cause sloppy steering, they would have to be EXTREMELY worn out. Wheel bearings tend to be noisy critters when they start wearing out, I would think you would hear them. Secondly, if the wheel bearings were so worn as to allow slop, that should have been caught during a wheel alignment when they check for things like ball joints, tie rod ends, etc. But wheel bearings are a 5 minute check.
Old Feb 10, 2021 | 10:07 PM
Margate330's Avatar
Margate330
Hi matts,
Is your brake pulsing gone after they did the new parts?
At least that would be some good news to have that fixed.
Old Feb 11, 2021 | 06:50 AM
matts6887's Avatar
matts6887
well im gonna have my indy shop look at it monday and hopefully what they find wont be too much $ to fix
Old Feb 17, 2021 | 02:24 PM
Jonf's Avatar
Jonf
7th Gear
Hi Matt, I'm experiencing the same issue with my RX350 2006 model, I believe the front wheels bearings are to blame, I have replaced, brake rotors, lower control arm bushings, brand new tyres all around, turning into a long sweeping right-hand corner at speed I can definitely hear worn wheel bearing noise coming from the front of the car. Please let us know what your service centre comes up with. Cheers Jon (from Australia).
Old Feb 17, 2021 | 03:24 PM
matts6887's Avatar
matts6887
well actually my "issue" is not bearing related; but my steering "worm gear" which is a gear that helps steer the vehicle and is inside the rack and pinion is on its way out as I was and still am having a "wobbling" of the steering wheel at 65mph or above highway speeds. I knew it couldnt be the tires as i had all 4 rotated and re balanced so that was out; and it wasnt my alignment which i had checked; and so after several hours of testing my indy shop confirmed that it has to be the worm gear that is slowly on its way out; but Im not gonna do anything with it yet as far as replacing it goes because that is very big bucks in the thousands(1000 bucks u.s. plus)! so Im gonna leave it be unless the rack starts making noises when i turn or starts leaking power steering fluid at which point i will have to bite the bullet and get it taken care of.
Old Feb 17, 2021 | 03:56 PM
Jonf's Avatar
Jonf
7th Gear
ok, thanks for the quick reply, I will get to the service centre to see if mine is the same, it's really starting to bug me as I do a lot of highway driving. thanks
Old Mar 30, 2024 | 05:47 PM
WyyDee's Avatar
WyyDee
1st Gear
Hey there, any updates on this issue? I know this is a few years old now but I'm experiencing something similar.
​​​​​​Thanks!
Old Mar 30, 2024 | 05:55 PM
Jonf's Avatar
Jonf
7th Gear
​​​​​​Thanks!
Yes replace both the front wheel bearings, even if a mechanic tells you they are fine. I had to go to 3 different places before I said to them just humor me and replace both of them….Problem fixed! I wasted a lot of money listening to so called professional’s!
Jbthompson
Oct 5, 2024 06:38 PM
wculbert
Apr 16, 2023 08:26 PM
Mfnheff
Aug 26, 2013 09:42 PM
tangcoral
19
Oct 13, 2010 04:43 PM
Maxx941
13
Dec 29, 2007 05:29 AM
