valve cover gaskets
Not a mechanic, but long time owner. I would say only if you have a leak should you mess with taking the engine apart to check on the gaskets. But the 3.5 engine is not prone to leak, nor was the 3.0 engine - so most likely never, unless you have a leak. And even then, I would have to weigh the leak vs the expense. A drop every day is a different situation than a quart every 1000 miles.
What makes you ask this? I'd be looking later on when you can afford to fix your transfer case leak......I'd stop dwelling on all this weird stuff & do the basic maintenance as needed....
well because its happened to people before and i was just kinda wondering if there was a set amount of time per say.
IK you can't afford it, but if you really want to fix & do it all.....Really best to drop the cradle, Reseal the timing cover, throw a w/p at it as well as reseal the i/m, change the bank 1 coils, replace all 6 plugs, reseal the two piece oil pan, change out the vvti., fix the trransfer case leak throw a rack at it as well........Doing this is a lot cheaper then a 36/48 month loan on a gen3 of which will possibly need this done as well.......
Valve cover gaskets are a big money maker for repair shops.
Since most people don't keep their engines clean there is no way for a mechanic to tell how bad the leak really is but they will always quote the job if they see oil since it's gravy $$$ job.
If the engine hasn't been degreased in a long time even a slow leak can look like an urgent repair when it isn't
I do also have the bank one cat code and am debating replacing it while I have everything out already. The only problem is the cat change doubles the cost of what I was doing.
I also have a very very small seep around the rack's main seal, but since I put in stop leak, I haven't had to add P/S fluid. So while I thought about changing the rack, I will probably wait since I have that Cat issue.
The two part oil pan intrigues me. I realize this is a whole different thread/conversation itself so I won't g on about it.
I will add I get all my parts from Rockauto when I have time to plan and wait.
Yah, the 2 piece, lower and upper oil pans on RX350 were a first for me, but they both use FIPG (silicone gasket maker, I used Threebond spec'd in SM, been fine) instead of rubber gaskets. An extra 2 surfaces to clean and goop up, but comes apart and goes together easy enough.
Frank1984
Dec 25, 2020 08:58 PM
