Good Lexus-ites of the internet,
I tried searching but did not find a thread that answered my questions fully.
2004 RX330 FWD Japan built, ABS and VSC lights came on, I do not have Techstream nor a 32bit Windows 7 PC handy to use a cracked version.
My Innova scan tool is only good for GM/FORD and oddly enough Isuzu ABS codes.
One of two options I am hoping someone can kindly help with.
I do own one of those Chinese Techstream USB adapters I never was able to make work for my 2016 4Runner, if there is a cracked Techstream that will install on widows 10 I am happy to try that.
OR, a scan tool of some type on Amazon that can read the ABS codes so I know which wheel sensor is likely causing the issue whether it failed or just needs a cleaning.
My body is not what it used to be to jack the whole thing up and remove all the wheels and sensors if I can help it.
Thank you in advance for helping a lazy lover of this 16 year old RX.
I actually use techstream 14.30 on two Windows 10 64 bit, and they worked perfectly fine on two separate laptops.
https://blog.uobdii.com/toyota-tis-t...setup-on-win7/
Just this morning I hooked up Techstream using the $40 Amazon OBD2 adapter. You just install the driver and it's good to go. I paid for the $65 2 day license and it worked great on my regular Windows 10 64bit laptop.
Thanks everyone, I am awaiting a reply from that mhhauto forum so i can register and request a activation code for TIS14.30 I ordered an OTC ABS scan tool that was supposed to be able to pull codes from our RX but it said ABS system not detected, so back to Amazon that little guy goes.
