Does this sound "normal"?
Old Jun 10, 2020 | 12:37 AM
Margate330's Avatar
Margate330
Originally Posted by DennisMik
It sounds like it could be a valve lifter. Why don't you try running some Seafoam in the oil to clean the oil passages and see what that does.
Mine was making some "lifter ticking" noise and Seafoam in the engine oil treatment fixed it completely.
It was only one lifter but it was loud and very obnoxious.
Old Jun 10, 2020 | 08:19 AM
matts6887's Avatar
matts6887
thats why im thinking of getting some seafoam myself and dropping in in but possibly not until my next oil change
Old Jun 11, 2020 | 10:50 AM
treefiddy9's Avatar
treefiddy9
today it started up without the CLACK and only has normal fuel injector clicks... weird. I'll never understand this car. the stereo still sounds like crap though.
censor test: matsu****a! heh
Old Jun 16, 2020 | 06:51 PM
Felix's Avatar
Felix
Sounds like a collapsed hydraulic lifter thats not pumped up.........Seafoam can possibly help. A vvti issue has nothing to do w/ lifters.....Another words if you had a vvti cam phazer issue, its not going to make that kind of noise, which is clearance thanx to a lifter or two thats not pumped up.....Add a can of seafoam, let it run for a bit, possibly drive it around easy for 10-20 miles & then drain the oil & swap the filter out & yes use synthetic oil w/ a quality oil filter.......btw a hydraulic lifter has tight tolerances to take up the slack allowing the valve train to operate w/ zero tolerance vs a solid lifter which needs a set clearance such as on the 1mz/3mz motors......
Old Jun 17, 2020 | 05:26 AM
treefiddy9's Avatar
treefiddy9
it started shortly after I changed the oil... it had conventional oil in it and I switched to synth. I probably knocked some sludge loose and that sludge is probably elsewhere now. I've never experienced a noise like this going away on its own and I've been doing this for decades.
Old Jun 17, 2020 | 06:27 AM
Felix's Avatar
Felix
Best to stay w/ synthetic oil.......I don't see why anyone would use dino oil in this day & age.....
Old Jun 17, 2020 | 07:06 AM
matts6887's Avatar
matts6887
Well; ive been getting my oil changed with just a synthetic blend and ive had no issues or problems thus far and im almost due for my next oil change at 146000 miles; im at 145,000 and change miles currently.
Old Jun 17, 2020 | 08:09 AM
treefiddy9's Avatar
treefiddy9
ikr, the stealership did it... right before I bought it. I wasn't planning on buying the car, but it was there, price seemed right. I drove it about 1000 miles and changed the oil to synth. did the trans too.
Old Jun 18, 2020 | 08:37 AM
matts6887's Avatar
matts6887
just a fyi; u only need to do oil changes every 5000 miles which is what lexus says.
Old Jun 18, 2020 | 10:44 AM
treefiddy9's Avatar
treefiddy9
yeah... I just didn't trust the stealership and didn't want conventional oil. I think I have it at 7500 miles, but may switch it to 5k.
Old Jun 18, 2020 | 05:45 PM
Felix's Avatar
Felix
Basically change the oil & filter in timely matter.....I'm not going on 'bout synthetic's, synblend's & dino oil......thats for bob the oil guy board....btw you have any idea what the blend ratio of synblend's?
Old Jun 18, 2020 | 05:47 PM
treefiddy9's Avatar
treefiddy9
supposed to be about 50/50... never saw a point in using it. reminds me of using "Slick 50" in my dino oil.
Old Jun 18, 2020 | 05:54 PM
matts6887's Avatar
matts6887
realistically its best to follow the maintenance indicator; when that starts flashing and then goes out; its letting u know that i think its like 500 miles give or take til its actually "due" for oil change at which point the maint. required light will stay on all the time til oil change is performed.
Old Jun 18, 2020 | 05:56 PM
treefiddy9's Avatar
treefiddy9
yeah, I know... I set it at 7500. I also set my garage as the dealer to take it to.
Old Jun 18, 2020 | 06:06 PM
Felix's Avatar
Felix
LOL...you'd kinda think it would, but not......I basically change oil at 3-5k w/ a quality filter, one dedicated to synthetic oils......
Franknslot
Feb 21, 2020 09:59 AM
gwblackbur
GX - 1st Gen (2003-2009)
Sep 29, 2018 10:39 AM
Sheriffen
Apr 20, 2017 06:04 AM
PUYA
RC - 1st Gen (2015-present)
Jul 16, 2016 02:41 PM
