Check Engine, VSC, Trac Off - Code P0705
Old Jun 15, 2019 | 10:49 PM
01BabyLexy's Avatar
01BabyLexy
Default Check Engine, VSC, Trac Off - Code P0705
Hello,
Recently, my car came up with check engine, vsc, and trac off light. I got the code scanned and it's showing P0705 - Transmission Range Sensor. The car idles and shifts fine while driving. However, whenever I shift into Neutral, the car stalls and engine turns off everytime.
I took my car to my trusted local mechanic and he said he doesn't know what the problem is. He recommended that I take it to a Lexus dealership.
What should I do?
Old Jun 18, 2019 | 08:27 AM
iMSQ's Avatar
iMSQ
Talking
Originally Posted by 01BabyLexy
Hello,
What should I do?
Old Jun 18, 2019 | 09:49 AM
5W40's Avatar
5W40
Check this sensor, either clean or replace it if u can.
Old Nov 25, 2022 | 10:04 PM
amal12's Avatar
amal12
1st Gear
Default P0705
I've changed the inhibitor switch and align it properly, but the faults remains same , when i check the live data , it shows p/n switch on in every time. Rather i move the gear lever to any gear that stays same. Fo you have any idea where is the park nutral switch is?
Jbakyy
Dec 13, 2022 10:35 PM
Joppa013
Oct 27, 2017 12:44 PM
johnnylt
Mar 15, 2016 05:23 PM
LexHelp
Sep 16, 2014 07:23 AM
StanVanDam
Jun 1, 2010 12:19 PM
