Plug and play remote start
Old Jan 15, 2019 | 06:24 PM
Rrohde84's Avatar
Rrohde84
Default Plug and play remote start
I’m new here and was wondering if there is any plug and play remote start for our vehicle I can’t see to find one
Old Jan 15, 2019 | 08:35 PM
Audiqv8's Avatar
Audiqv8
Not knowing the year of your RX it is kind of hard to help. Do a search for the following parts number B078NHBHBC for a oem plug and play remote starter.
Old Jan 15, 2019 | 09:48 PM
DennisMik's Avatar
DennisMik
IIRC, Lexus did not offer a remote start for the RX until 2010, which is the 3rd gen RX. I doubt if it is compatible with our 2nd gen cars.
Old Jan 16, 2019 | 06:03 AM
Rrohde84's Avatar
Rrohde84
I have a 2007 rx 350 is there not an after market option or what is the best one to get if there is no plug and play option.
Old Jan 16, 2019 | 07:36 AM
Audiqv8's Avatar
Audiqv8
You might want to view this video and follow his instructions on setting the up the remote starter to use your existing Lexus key FOB just like the OEM for later Lexus.
Old Jan 16, 2019 | 06:10 PM
Lexuswiz's Avatar
Lexuswiz
This OEM unit is not 100% plug and play although very close. You need techstream to activate it, otherwise it's an expensive paperweight. Had this issue with a SmartKey Camry I did one on. It also follows the same SmartKey glitch where if you open the drivers door the remote start shuts off and you need to restart the car before taking off.
If yours uses a standard key and does not have SmartKey or Proximity key capabilities (like the 2006 LS430 which has a key but can be started without inserting it) then there is zero plug and play options. I had to manually wire my 2005 RX330 for a Viper remote start and it is difficult to do.
https://www.youtube.com/watch?v=0JA6p83YPDc
This person is for sure using an aftermarket bypass with 3xLOCK compatibility alongside his compustar remote start so it can be started using either. Only thing I can't tell is which bypass is he using. For sure not a DBALL2/3 as the 3xLOCK functionality doesn't exit for this gen RX.
johnnieade
RX - 3rd Gen (2010-2015)
Sep 30, 2018 05:14 AM
fezzy
Jul 13, 2017 05:46 AM
Arnsbug
Jun 20, 2017 01:43 PM
jnjmatts
Dec 9, 2013 02:43 AM
Brewdog
Oct 11, 2011 11:11 PM
