2008 RX350 windshield washer problem
Old Jan 9, 2019 | 04:40 PM
albyvt's Avatar
albyvt
8th Gear
Default 2008 RX350 windshield washer problem
I have a 2008 rx350 the will pump washer fluid to the back and to the headlamps but not to the windshield. I put 12v to the front pump and it works fine. From the owners manual it looks like there is only one fuse for all the pumps. i think there is a relay for the front that is bad but i am not sure where it is. If anyone has any info on this problem or knows where I can find a wiring diagram i would appreciate the help.
Old Jan 9, 2019 | 05:32 PM
Nad1370's Avatar
Nad1370
You are right, just 1 fuse for the washer circuit.
You have most likely a clogged up or pinched washer hose going to the windshield nozzles.
Even possible both clogged nozzles.
Trace your washer hoses and see where the restriction is.
Old Jan 9, 2019 | 05:38 PM
albyvt's Avatar
albyvt
8th Gear
Wish that was the case but the pump is not coming on so for now I have moved the front hose to the back pump and it will spray through the front hose just fine. I need to figure out why the front pump is not coming on.
Old Jan 9, 2019 | 06:11 PM
Nad1370's Avatar
Nad1370
I thought your pump worked from your post.
So you used a 12v source to manually turn the pump on, right?
Try checking power on the pump connector.
If i remembered my Dad's 07 350, washer operation was controlled by ground so one wire should have constant power at the pump connector w/ the key ON. (I cant remember which one)
If you do have power, then the problem is in ground side.
Washer switch or wiper ecu (relay) granting that your wiring is intact.
Old Jan 9, 2019 | 06:18 PM
albyvt's Avatar
albyvt
8th Gear
Thanks for the suggestions but I have checked and there is no power to the connector. Any idea where the relay is located. I realy dont want to tear apart the steering column until I have found and checked the pump relay. Any idea where I can get a wiring diagram for the car?
Thanks
Old Jan 9, 2019 | 07:10 PM
Nad1370's Avatar
Nad1370
Thanks
Before you go to the relay, find out why you dont have power on one of the wires at the pump.
You should have battery voltage on one of the wires going to the washer motor connector with the key in the ON position.
This wire is a straight shot from the 20amp washer fuse.
No power source, no worky worky.
Old Jan 11, 2019 | 03:20 PM
DennisMik's Avatar
DennisMik
FRONT WIPER/WASHER
REAR WIPER WASHER
imahogg
RX - 3rd Gen (2010-2015)
Oct 10, 2019 05:28 AM
Israelq95
Apr 17, 2019 04:29 PM
lex79
GX - 1st Gen (2003-2009)
Jan 23, 2016 10:04 AM
300s4life
RX - 1st Gen (1999-2003)
Jan 22, 2010 10:58 AM
