power steering pump
Old Dec 16, 2018 | 03:37 PM
matts6887's Avatar
matts6887
Default power steering pump
on the rx330/rx350 where is the power steering pump located? Is this a easy diy fix if I find out mine ever needs to be replaced? or is this something i should have a trusted shop replace for me?
Old Dec 17, 2018 | 06:57 AM
Audiqv8's Avatar
Audiqv8
The video is for a 2005 Sienna which uses the same engine as an RX330. The pump is located on the passenger side under the engine. You will need to raise the car in order to access the pump. The hardest part is to loosen the high-pressure banjo bolt there is an electrical connection which must be removed first.
Old Dec 18, 2018 | 12:22 PM
matts6887's Avatar
matts6887
thanks but it sound like I may have to leave this to a shop because i do not have the tools or facilities to change that out. If I did i would consider doing it myself but alas i cant. and i sure as heck dont have the $ for the tools etc.
BrittonJ85
Apr 28, 2010 10:39 AM
tritron
SC400 / 300 Classifieds
Apr 23, 2008 11:42 AM
Tymboo
Nov 13, 2006 08:44 PM
andrew_A_3
Oct 13, 2006 01:35 AM
