Sunroof is not working
I have an 04 rx330 I cannot get the sunroof to open or close, I have done the reset listed here as well as checked the fuse for the sunroof. Has anyone had any similiar issues or know how to fix it please let me know. I am thinking that the motor itself is burned out.
Last edited by 05ls430518; Dec 3, 2018 at 11:14 AM. Reason: Made a grammatical error
When was the last time it worked? Have you checked the fuse? If the fuse is OK, I would reset the whole system by disconnecting the battery for a 5 minutes and check. However you will lose your pre-sets on your radio and seats. But you can set them up again easily.
I have done the reset listed here as well as checked the fuse for the sunroof. I also purchased the vehicle 2 weeks ago.
The motor is dead is what I gathered got a print out of the wires tested everything, if you need to you can manually shut the hatch by removing the dome light plastic its 4 screws.
Before going to the dealer, try re-calibrating the one-touch operation:
1. Turn ignition to "on".
2. Operate the moonroof (by holding down the correct button) to:
a. fully closed (if it's not already)
b. full tilt up
c. full tilt down
d. full slide open
e. full slide closed
3. The buttons should now support one-touch operation. Also, the jam protection function should now be enabled as well.
My moonroof doesn't work (inner damage). I'm going to replace it, but I can't find 2nd Gen RX at junkyards in my area. Does anybody know what Lexus/Toyota model I can use as a donor for moonroof ASSY? Thank you.
jetcobra
Mar 9, 2018 02:57 PM
mb12345
Mar 9, 2011 07:22 AM
