false ABS activation
Old Nov 23, 2018 | 07:03 AM
gpbiker's Avatar
gpbiker
Default false ABS activation
about 25% of the time when coming to a very slow stop, the abs system kicks in, no lights for ABS or braking system ever light up. Diagnostic never shows any issues. replaced master cylinder, rotors etc. Any ideas?
Old Nov 23, 2018 | 07:34 AM
ukrkoz's Avatar
ukrkoz
Damaged or dirty ABS sensor. Pull out and clean in the front. rear ones, I don't know how to get to.
Old Nov 23, 2018 | 08:12 AM
gpbiker's Avatar
gpbiker
thanks, sensors clean, rust free and seated...rear sensors sealed.
Old Dec 3, 2018 | 11:18 AM
05ls430518's Avatar
05ls430518
I just bought my 04 rx 2 weeks ago and it does the same thing I am wondering if the brake pads are not seated all the way in the caliper and that is causing some of the issue.
Old Dec 3, 2018 | 11:31 AM
shikbas's Avatar
shikbas
check the tuning ring inside the hub ,using the sensor opening,some time ago it happened to me,took each tire out,abs sensor out,look inside through the opening and spin the hub,my self found broken ring,,they took the axle out,removed the old ring and pressed a new one,I think you can find it on ebay
Darzan23
Apr 15, 2017 07:00 PM
gsCrazy
Mar 20, 2017 09:26 PM
Anthony81
May 18, 2016 09:36 AM
kldckldc
Aug 25, 2015 06:31 AM
duane
RX - 1st Gen (1999-2003)
22
Jul 8, 2007 04:55 AM
