A/C Charging RX 400h 2008
How do I keep the engine to stay running to charge the A/C?
I would also like to keep the engine running to troubleshoot a cooling fan.
2008 RX 400h
2008 RX 400h
To keep the engine running just press down on the gas pedal. However, you don't need to do this to re-charge as the AC is completely electric. AC is powered from the hybrid batteries and the engine will restart automatically as needed to recharge the batteries. But the gas pedal trick will work for your fan troubleshooting.
Holding down gas pedal will work only for a brief moment on hybrid. Then ECM takes over and shuts it down.
You have to place system into what is referred to as maintenance mode. Then ICE runs just like a regular vehicle one. It returns to normal operation after restart.
DO NOT refill ac unless you checked it for vacuum leaks. Or, you'll be tossing $$ at it continuously.
Threxx
06-27-07 11:40 AM
