Tachometer Repair or Replacement
Old Apr 18, 2018 | 02:00 PM
hennemark's Avatar
hennemark
Default Tachometer Repair or Replacement
My 2004 has just under 200,000 miles on it. It's the best car I've ever owned. The only thing that doesn't work is the dashboard tachometer. For about 1000 miles it stopped working intermittently, now the needle sits at 0. The speedometer gives accurate readings, and the car runs and shifts great. I recognize that I don't really need a tachometer, and never paid a lot of attention to it. It's just a cosmetic thing - I like things to work the way they were designed to work. If it can be fixed easily and cheaply, I'll probably do it. I'm not even sure where the tachometer sensor is, whether it's separate from the speedometer sensor, and how the mechanism works. If anyone has any experience or insight into this, please share.
Old Apr 19, 2018 | 06:46 AM
Audiqv8's Avatar
Audiqv8
The tachometer is controlled by the ECM. Either the crank signal or the cam signal or both are used by the ECM to determine engine speed. A quick test is to hook up an OBDII reader which can read engine RPM. If either crank or cam signal is missing your engine will run rough or not at all. Most likely it is the instrument cluster that is bad.
Old Apr 19, 2018 | 07:19 AM
Htony's Avatar
Htony
IMO, meter itself maybe OK. The electronic signal driving the meter is in question.
tpnotch420
May 10, 2023 01:24 PM
CHUBYBALL
148
Feb 27, 2023 11:24 AM
hennemark
Apr 18, 2018 02:00 PM
anx4evr
Sep 19, 2013 08:48 PM
ck90211
Apr 13, 2010 06:05 AM
