Transmission problem
Old Mar 12, 2018 | 05:08 AM
GAGOO's Avatar
GAGOO
Default Transmission problem
I have a 2008 lexus rx 350 ...i have a problem a kick between 2nd and 3rd gear when driving at steady gaz pedal ... I went to the garage and they scan it and made the computer indentify the tranmision ..the car worked properly for almost 5 days and the problem came back ..each time they scan it and reload the scan the car work fine for a few days only..whats going on?
Old Mar 12, 2018 | 06:53 AM
coolioe93's Avatar
coolioe93
I’ve found it to be normal with the 2nd gen RX. Resetting the computer resolves it for a bit, but for me it always comes back in the next few days as the transmission recalibrates itself.
Old Mar 12, 2018 | 05:58 PM
ToledoRX's Avatar
ToledoRX
Have you taken your car to a shop to have the ATF drain and fill? A fluid change does wonders to smooth out the transmission.
Old Mar 13, 2018 | 06:49 AM
GAGOO's Avatar
GAGOO
indeed they changed oil and filter too ....even the dealer didnt figure out whats the problem yet ...... is it a problem with valve body ?
Old Mar 13, 2018 | 06:50 AM
GAGOO's Avatar
GAGOO
your reply is logic ...whats the solution
Old Mar 13, 2018 | 02:58 PM
5W40's Avatar
5W40
My 06 RX330 used to jerk or feel like rear end at ~55 km/h but NOT every time, change ATF doesn't work! but after front transfer case and rear differential gear oil changed that jerk rarely happens. so either a software update or a transmission adaptive reset and proper relearn procedures [NOT battery disconnect] after a ATF and gear oil services may works well.
GAGOO
RX - 1st Gen (1999-2003)
Sep 19, 2018 04:50 PM
paulvcao79
RX - 3rd Gen (2010-2015)
15
Nov 5, 2017 02:47 PM
m1964
14
Mar 3, 2015 03:33 PM
sambet2004
Oct 13, 2012 11:33 AM
Jimbo2828
Oct 24, 2007 10:22 AM
