Engine overheat
Old Feb 27, 2018 | 04:08 AM
ChunksRX's Avatar
ChunksRX
Default Engine overheat
Engine overheating on slow speed and idle.
Replaced the radiator, fans are working fine, opened the thermostat valve also.
Still the problem exists.
​​​​​​Feont axke boots are wearing out faster coz of the over heat, I guess.
Pls help.
Old Feb 27, 2018 | 08:43 AM
NVAKeith's Avatar
NVAKeith
What year and model? (330, 350, 400h)
Old Feb 27, 2018 | 05:32 PM
chalkboss's Avatar
chalkboss
What do you mean by "opened the thermostat valve"? Are you referring to the bleeder located towards the rear of the thermostat housing? All this does is bleed air out of the system after opening it up for service, which you need to do after radiator replacement. Did you bleed it at the upper hose too (at radiator)- there is a spot for this as well. Sounds like you may still have air in it and need to bleed it out.
Old Feb 28, 2018 | 05:34 AM
ChunksRX's Avatar
ChunksRX
Originally Posted by nvakeith
what year and model? (330, 350, 400h)
rx330,2004 model
Old Feb 28, 2018 | 06:30 AM
ChunksRX's Avatar
ChunksRX
It seems like this thermostat valve will open when the engine temperature goes up a certain level. So that tye engine coolant will fully flow into the circuit.
Old Feb 28, 2018 | 06:31 AM
ChunksRX's Avatar
ChunksRX
Simply removed this valve so all the time there will be full flow of the coolant to the circuit.
Old Feb 28, 2018 | 08:22 AM
chalkboss's Avatar
chalkboss
You removed the thermostat? Not sure why you would do this; if removed will cause your overheat. I suggest replacing the thermostat and seal and leave the system as the factory intended.
Old Feb 28, 2018 | 11:42 AM
OG Member's Avatar
OG Member
Pls help.
Here's my original thread back in '17 with a similar issue - https://www.clublexus.com/forums/rx-...erheating.html
The resolution to my issue is referenced in post #8
Hope this helps you out!
Old Feb 28, 2018 | 11:56 AM
ChunksRX's Avatar
ChunksRX
I'm pretty unsure if the mechanix done air bleeding.
I will ask to redo it.
Thanks for the reply😃
gr8fulRed
Jul 2, 2018 07:19 AM
velani
Jun 9, 2018 02:18 PM
razzuh
40
May 18, 2018 08:22 AM
Megaman096
Apr 25, 2014 08:00 PM
twojayzee
GS - 1st Gen (1993-1997)
May 9, 2003 09:29 PM
