Problems
Old Feb 21, 2018 | 02:07 PM
Gazz's Avatar
Gazz
Default Problems
Hi all
I own RX300 model 2004 and there is 2 problems.
the heater only blows almost cold air on the passanger side in every mode, I have done following, new thermostat, all servos are working correctly, cleaned out the heater core any idea what is going on ?
And the other problem is that the cruse control did some times not go off pussing the on/off and sometimes not go on at all. But now it wont go o at all , any ideas ?
Thanks in advnce
Old Feb 22, 2018 | 03:33 AM
nwfsnake's Avatar
nwfsnake
The cruise control sounds like the brake switch might be bad, are your brake lights working properly? Have you checked for any AC error codes? Do a search for the procedure to get them and what they mean. Good luck!
Old Feb 26, 2018 | 01:02 PM
leroyjnav's Avatar
leroyjnav
Hi Gazz,
I have had that problem before on my 2001 RX300 with cold air blowing - it only uses one servro for both passenger and driver hot/cold air. If you have a RX330/350 it has a dual temp system, then the servo that controls the hot/cold to the passenger is bad - at least on the RX300 these tend to go bad often as it is located next to a hot pipe connected to the heater. You can replace this yourself and save a lot of money, though the part itself is quite expensive. I bought this part from Lexus the first time, and them off of Amazon the second time.
I also have the same problem with the cruise control on my 2001 RX300. Most of the time it worked, sometimes it just went off automatically when driving and then I had to step on the gas. Mine finally went out after 200,000+ miles, the cruise light comes on, but no cruise control. I haven't fixed it yet, but I took a look into why, and it turns out that there is a module that controls it in the dashboard that needs to be replaced - you can probably find that info in one of the forums here.
Old Feb 27, 2018 | 08:38 AM
coolioe93's Avatar
coolioe93
There is an in cabin temperature sensor by the drive side knee panel. Mine had a lot of dust on it when I cleaned it a couple of weeks ago. Before it was cleaned, my driver side temperature setting would not match the temp of the air coming out of the vents. I cleaned it out with a Q tip. I would recommend you doing the same to see if it fixed the issue
Old Jun 27, 2018 | 07:16 AM
Dschwartz's Avatar
Dschwartz
Facing same issue in my 2002 es300, since this is a dual system are there (2) sensors?
randy57
RX - 1st Gen (1999-2003)
Nov 23, 2017 08:11 AM
peebles
Jun 12, 2013 11:30 AM
T8LEX
Dec 9, 2010 07:08 AM
GS2low4NYC
Jan 8, 2010 09:41 AM
BAD RIDES
May 17, 2008 08:23 PM
