Leak - need help in identifying the part
Old Feb 12, 2018 | 10:11 AM
reisingdw's Avatar
reisingdw
Question Leak - need help in identifying the part
My 2004 RX 330 has a "hot" smell after a drive. Oil and trans fluids are all good. No drips on the garage floor under the car. BUT inspecting around the car, I did find a wet oily rubber cup near the front left wheel. But I don't know how to identify what this arm or rubber cup is, in order to do further research. I suspect many of you may recognized this part in the attached photo. Any info is appreciated. Darrell
Old Feb 12, 2018 | 10:58 AM
nwfsnake's Avatar
nwfsnake
Unfortunately, the all too often steering rack leak. Do a search for further info.
Old Feb 12, 2018 | 12:02 PM
NVAKeith's Avatar
NVAKeith
Aside from that leaking steering rack.... Do you have AWD? When our transfer case sprung a leak it dripped right on the exhaust giving off a burning smell.
Old Feb 13, 2018 | 12:56 PM
reisingdw's Avatar
reisingdw
ThanX nwfsnake - that would be an expensive fix and out of my skill set. The Lex has 225K miles on it and I've never had to do a major repair. I suspect after 14 years, its about time some things begin to fail.
Old Feb 13, 2018 | 12:57 PM
reisingdw's Avatar
reisingdw
NVAKeith - Yes, it's AWD. I'll take a look at the transfer case and see what I can discover. Good suggestion.
Old Feb 13, 2018 | 01:18 PM
crimedog's Avatar
crimedog
Try some Lucas Power Steering Stop Leak. I was skeptical, but mine had the same leak. I replaced some of the power steering fluid in the reservoir with the Lucas stop leak. Hasn't leaked a drop since. Not one drop. You have nothing to lose but about ten bucks if it doesn't work.
vnk
May 3, 2019 03:01 PM
langer51
GX - 1st Gen (2003-2009)
Feb 9, 2016 07:49 PM
Oliverted
Apr 7, 2011 07:08 AM
Farino81
Jun 8, 2009 07:55 AM
AzSc4
Sep 17, 2006 12:50 PM
