need help w/PS pump leak
Old Nov 2, 2017 | 09:47 PM
boosteddsm's Avatar
boosteddsm
Default need help w/PS pump leak
2009 RX350. Reservoir is empty and is leaking quite a bit at, what looks like, the pulley shaft. Serpentine belt gave out and may have whacked the shaft seal? I removed the hoses, wire harness, and 2 bolts through the pulley holes and the pump won't budge. Are there other bolts holding it on and where are they? Am I on the right track here? Is the seal replaceable if I pull the pulley or am I better off getting a new pump? I searched here and didn't find anything about ps pump leaks. Thanks all.
Attached Thumbnails need help w/PS pump leak-20171102_215912.jpg
Old Nov 3, 2017 | 08:38 AM
nwfsnake's Avatar
nwfsnake
I looked at the picture of a new pump on Rockauto.com and it appears there are 3 bolts holding it on, not two. I think you may have missed one...
Old Nov 3, 2017 | 08:51 AM
05RX330AWD's Avatar
05RX330AWD
From the RX330 Repair Manual...
shouldn't differ from a RX350, hopefully this helps.
Attached Thumbnails need help w/PS pump leak-capture1.jpg   need help w/PS pump leak-capture2.jpg   need help w/PS pump leak-capture3.jpg   need help w/PS pump leak-capture4.jpg
Old Nov 3, 2017 | 02:18 PM
boosteddsm's Avatar
boosteddsm
Thanks but it's different. There's no bolt going through the pulley and no bolts on each side...
Old Nov 3, 2017 | 03:42 PM
05RX330AWD's Avatar
05RX330AWD
My bad, the engines are completely different, but that slipped my mind when I posted...
I have an excuse, I'm a senior.
Hopefully someone who actually owns a RX350 with a Repair Manual or has been through the experience can help out.
Old Nov 3, 2017 | 08:30 PM
boosteddsm's Avatar
boosteddsm
No problem, I figured it out. For future reference:
Disconnect soft hose, regular hose clamp. The hard line is secured with a 17mm banjo bolt and one piece that holds both crush washers.
Remove 10mm bolt from bracket securing pressure/hard line
Disconnect the pressure sensor wire harness
Remove (2) 14mm bolts that are accessed between the pulley spokes that secure the pump. Then pry it back/down and out.
There is a shaft seal that got destroyed by a mangled serpentine belt. Picking up a reman pump from the parts store tomorrow, hopefully no drama putting in. Thanks again.
Old Nov 4, 2017 | 04:44 AM
05RX330AWD's Avatar
05RX330AWD
Great that worked out for you thus far.....
I am sure your findings will be useful for other RX350 DIY.owners.
Hopefully my RX330 will be the last vehicle I own in this lifetime, at least I have the Repair Manual to refer to.
jeanD1010
Jan 17, 2018 02:34 PM
RA030926
Apr 12, 2017 10:47 AM
VQT
Oct 21, 2001 10:32 AM
