07 rx 350 headlight cleaner
just picked up a 2007 rx350 with 122K (LOVE IT)
tried everything to get the cleaner to work, nothing.
with the headlights on, off, windshield wipers on, off.
When I press the button I can hear a little sound, the
motor is trying to work but they do not lift up and nothing comes out.
Anyone know what it could be?
A second place to fill with fluid?
I doubt its the fuse since I read and every fuse that say headlight cleaner, it also controls a lot of other stuff. So I didn’t even bothered with the fuses.
Any help would be appropriated.
Thanks in advance guys!!
The pickup tube is placed higher than the main windshield washer
pickup. The fluid reservoir is nearly full, right? If it is full and you
are hearing the pump run, check around under the front end after
the attempt. Any puddles forming from leaking hoses? This might
also happen if the spray head(s) are jammed and unable to pop up.
