Lexus RX 330 struts
Old May 12, 2017 | 08:31 PM
donaldj's Avatar
donaldj
Default Lexus RX 330 struts
all the struts were replaced and thumping continues with mechanics unable to fix. What is the main problem in this situation?
Old May 13, 2017 | 02:22 AM
05RX330AWD's Avatar
05RX330AWD
The location of the thumping? Rear, front, which side?
Old May 13, 2017 | 04:38 PM
Lexuswiz's Avatar
Lexuswiz
Look into all rubber parts/bushings. Also look into the sway bar links/stabilizer bars. My drivers side link just blew out it's bearing and it clunks when the front of the car dives when stopping. Just ordered it before typing this.
Old May 14, 2017 | 08:36 PM
donaldj's Avatar
donaldj
rear thumping. passenger side. maybe the sound travels along the undercarriage. Did the rubber parts including sway bar rubber. If the wrong struts were installed would that cause the problem? It has been persistent for six months or more. Unable to contain it as it returns after a few weeks.
Old May 15, 2017 | 05:40 AM
BlackLexRX's Avatar
BlackLexRX
Sounds like sway bar bushings. Start there as they are simple to replace and cheap.
Old May 15, 2017 | 09:15 AM
05RX330AWD's Avatar
05RX330AWD
I was hearing thumping in the rear passenger area & bouncing all over place . Today, installed some rear Monroe OESpectrum Refex struts with the OEM Mounts that were on the RX.......
No more thumping, no more bouncing . Decent struts, Caddy type ride, Lifetime Warranty, can't complain. Can't compare to OEM struts since mine were finished with most likely 140,000 miles of use.
That was in my case for the thumping issue. What brand of struts did you install?
Old May 17, 2017 | 08:10 PM
makarov's Avatar
makarov
Did you install strut tower bushings as well? On our Subaru there are rubber bushings in the top of the struts. They are a separate purchase from the strut inserts. They will cause clunking even with new struts if not replaced as well. Also sway bar end links have bushings too as well as the sway bar itself.
gookies
RX - 1st Gen (1999-2003)
13
Feb 2, 2019 10:57 AM
LazarusLng
Dec 19, 2014 03:00 PM
lostape45
Jun 26, 2014 11:58 AM
2hot2hold
Maintenance
Jul 9, 2004 09:57 AM
Rro
May 22, 2001 05:56 AM
