Led lights
Led lights
Can I covert my 2011 rx350 daytime lights to led and also can I replace my interior lights with led
If so where is best place to purchase
You can replace the high beam/DRL (they're both from the same bulb) bulbs with LED BUT I do NOT recommend this. DRL uses PWM to reduce output of a filament bulb, put on an LED and you get flickering which will ultimately ruin your LED. You can over come this but using big capacitors (sold as CANBUS eliminators/anti-flicker) but that will run your LED's at full power and most LED made for high beams are too bright to run at full power for DRL. I had to shut off the DRL function on Camry when I did this, so I could have LED highs.
Interior is easier with many kits sold on eBay/Amazon. I got a full set for $17 on eBay which included the license plate bulbs as well.
Led lights
Unless you're talking about the smaller bulb to the top of the high beam/DRL which runs always, that can be changed to LED without any extras.
The DRL is also the high beam so either way you're going to change it. It will work with the decoder but again, will run at full power which can be blinding if it's a powerful LED bulb which you should be using since it's your high beam when you need it.
Thanks and sorry to be so ill informed but the light on my 2011 rx350 that is on in the DRL mode is to the side of the halogen high beam/ low beam in my book it is listed as low beam but if i turn off the DRL mode it is the one that does not operate It is to the right on the drivers side of the halogen and to the left on passenger side. I hope this makes sense and thanks for your help
Thanks for your time
Check this out:
https://www.clublexus.com/forums/rx-...white-led.html
If you have anymore questions I can help, I see what that user is doing.
duffielove (04-29-17)
Duffielove, the model years are in the names of the subfora. 2011 falls under 3rd Gen which can be found here:
https://www.clublexus.com/forums/rx-...2010-2015-212/
