Lexuswiz's RX330
From my research most of the OBD2 to USB cables are the same unless you get a brand name one, so those you see in the $30-50 range are pretty much the same. Also, with Techstream you want the latest, I think the current is 10 which is what I have, works great on all my Toyotas.
That laptop you see in my pic is ridiculously helpful, most car softwares run on it for some reason (maybe ECU are more trivial then we think), I also work with BMW software and played around with Honda/Acura and Jaguar/Range Rover software. Cool stuff.
dedicated only for the Techstream. It is a 15" Dell Model which was built like a tank for office use back in it's glory days.
If the battery charger was red in color, you could mistake it for a brick, it has a carrying handle.
My teenage daughter used it for years, threw everything at it, couldn't believe that Laptop would never die after all that torture.
I had to use 3 paper towels with water to clean the screen when I dug it out of the bottom of a closet, the screen looks sort of like new now.
Don't try that at home, I wouldn't do that with my 27" Monitor for my computer or 1 year old Laptop.
From my research most of the OBD2 to USB cables are the same unless you get a brand name one, so those you see in the $30-50 range are pretty much the same. Also, with Techstream you want the latest, I think the current is 10 which is what I have, works great on all my Toyotas.Actually just purchased one in NJ, USA....
for around $20. US with mailing included.
My contribution to "Let's Make America Great Again"
Great to know, will look into it, the Laptop I have was bound for the Electronic Recycle Depot, now I have some use for it...
Enjoy!
I paid less than $100. maybe 7 years ago.
Even the original Battery still has a heart beat although is currently on life support.....
once I figure out Techstream, I most likely will need to invest in a inexpensive knock off Battery replacement.
My cheap LEDs seem to holding up well although I should check the ones at the bottom of the door panels, they were a tight fit & receive quite a beating when my wife slams the door.
The DRLs are 50% output of the high beams, I imagine the BECU would be involved for the output.
Most likely the prices have gone down by now, it will be interesting to see what you come up with & the cost.
Been looking into the CANBUS bulbs but I'm getting a clunk in the engine bay during acceleration I need to figure out first....
DRLs are required by law here & can't be disabled if the vehicle in question has them factory installed.
Classic cars are exempt but many will put on their headlights instead.
Hey guys, figured I'd chime in. Did the timing belt/water pump on my mom's RX330 about a year ago and it had around 125k miles at the time. The belt's backing was cracking all along the belt. Looked like it was on its last leg. Just saying you might want to do it soon if it hasn't been done in the interval!
I believe I used the AISIN timing belt/water pump kit off Amazon Prime.
Domo-Kun
Lexus Vehicles Classifieds
Aug 9, 2005 11:55 PM
