Time Query
Hi,
Just wanted to know if it is possible to change the clock in the RX 330 from a 12 hour to a 24 hour clock and if they have an option like the 90's accord where when you cross over time zones, you can hit a button and it goes one hour forwards or backwards?
thanks
thanks
i can only speak for the RX330's with Nav - i'm not sure how the standard LCD screens work - hopefully someone else will chime in with that info.
- i don't think you can use 24:00 format. there doesn't seem to be an option for that (i think the old RX w/ standard blue LCD had a setting for 24:00)
- you can specify your time zone. there are four buttons for the four U.S. time zones. so yes, you could just select it and it will switch over.
on a related note - the Nav system has auto-updating time. you can turn it on or off. when on, it uses GPS to get the current time. the Nav system also has a yes/no setting for Daylight Savings, so you need only press yes/no to update it when daylight savings starts/ends.
also, there is a calendar function which shows a nice digital calendar. i haven't played around with it yet, but i think you can set appointments and reminders, if you like that sorta thing.
C21Lexus
RX - 1st Gen (1999-2003)
Nov 3, 2004 09:21 PM
alanek
Jul 24, 2003 07:32 PM
