Lower front power outlet not working
Old Apr 7, 2015 | 05:43 AM
LittleRed's Avatar
LittleRed
Default Lower front power outlet not working
The power outlet in the tray under the front console in my wife's '08 RX400h has stopped working. I checked all three power outlet fuses indicated in the owner's manual and all are good (75 and 76 in the driver's side instrument panel fuse box and number 21 in the engine compartment (type B) fuse panel). Any ideas, or do I need to start ripping out the tray under the front console to find the problem? Thanks.
Old Apr 7, 2015 | 07:54 AM
LazarusLng's Avatar
LazarusLng
When in doubt, rip it out! Thats my philosophy.
Old Apr 7, 2015 | 08:03 AM
robbyk's Avatar
robbyk
This is kind of a dumb question but have you gone through the elimination process?. In another words have you plugged something in that particular outlet, then unplug what it is not working in that outlet and try it in ALL the outlets?.
Also connect in ALL THREE outlets something that you know it works for sure to see what happens.
If you already did that, before you start ripping the tray, I would use a voltmeter.
If you are patient enough you might want to order this gadget to help you test your cigarette lightEr for about $6.00 bucks:
Amazon.com: LCD Cigarette Lighter Voltage Digital Panel Meter Volt Voltmeter Monitor for Auto Car Truck (1piece): Automotive Amazon.com: LCD Cigarette Lighter Voltage Digital Panel Meter Volt Voltmeter Monitor for Auto Car Truck (1piece): Automotive
If you want to spend a little more, around $10.00, you can order this little guy to test your cigarette lighter and the charging system in any car.
Amazon.com: DROK® Car Cigarette Lighter Plug Battery and Charging System Monitor Blue LED Voltmeter with USB Charger: Cell Phones & Accessories Amazon.com: DROK® Car Cigarette Lighter Plug Battery and Charging System Monitor Blue LED Voltmeter with USB Charger: Cell Phones & Accessories
Mantist
Jun 22, 2019 09:58 AM
Benjam1n
Jul 26, 2014 01:19 AM
Jaden1
Apr 11, 2014 06:43 PM
floridaken
Aug 24, 2010 02:04 AM
Blackmarket
Jun 29, 2003 09:08 PM
