2nd Gen Maintenance Schedule
Old Apr 10, 2014 | 08:33 PM
cdnewton's Avatar
cdnewton
Originally Posted by alchemist
Push the middle section of each fastener down with a flathead screwdriver...this loosens them.
Man, that was easy .... i feel really stupid for not doing that sooner ... thanks for the tip.
Old Apr 11, 2014 | 04:08 PM
RX3302004's Avatar
RX3302004
So a 2WD RX has front transfer case fluid that needs to be changed? At what increment?
Old Apr 11, 2014 | 04:47 PM
RX330inFL's Avatar
RX330inFL
No gear oil with FWD. Drain and fill the transmission is all you need.
Old Apr 29, 2014 | 08:05 AM
mpatton's Avatar
mpatton
Originally Posted by RX330inFL
Hey, at least you are trying to read the existing material for your answers.
Vehicle maintenance and occasional repairs are usually much cheaper than new car payments.
Everyone will have different opinions on the maintenance intervals when you get outside what is noted in the Owner's Manual. My thoughts:
Transmission Fluid -- drain and fill every 30K (Toyota T-IV)
Front Transfer Case and Rear Differential -- replace every 30K (synthetic)
Coolant -- since this is long-life I would replace when doing the water pump at 90K
Power Steering Fluid -- once a year pump out the reservoir and add clean fluid (Mobil 1 ATF)
Brake Fluid -- 2 YR
Cabin Filter -- Yearly. I gently vacuum it each quarter to remove visible dirt.
https://secure.drivers.lexus.com/lex...ce-schedule.do
RX - forgive my ignorance with this car, but is there any way to tell if the PS fluid currently in the car is PS fluid or ATF? Is the suggestion to use ATF yours or is it lexus spec? I don't have my manual with me.
thanks
Old Apr 29, 2014 | 10:12 AM
RX330inFL's Avatar
RX330inFL
thanks
You can always search the Owner's Manual for any Lexus here:
https://secure.drivers.lexus.com/lex...nual-search.do
When you search you will find the following:
http://drivers.lexus.com/t3Portal/do...004rx33/63.pdf
So, yes it is correct in that there is no traditional power steering fluid in your RX. Rather, it uses a DEXRON II/III ATF. I picked up a cheaper bottle of fluid first to use while I was cleaning out the what was in the system. Would pump out the reservoir and add back clean fluid every couple of months. Once the system was cleaned out for the most part I started using Mobil 1 ATF and change it out much less frequently now.
Old Apr 29, 2014 | 12:12 PM
mpatton's Avatar
mpatton
Attachment 326546
Awesome. Thanks and thanks for the link to the manual, I was sure I had seen it online once before.
Thanks again.
Rezonans
Oct 24, 2013 09:05 AM
ted920
May 8, 2012 07:57 PM
OneGuyInCA
RX - 1st Gen (1999-2003)
Jan 23, 2011 04:58 PM
simplicity
Dec 17, 2010 08:01 AM
fallabel
May 16, 2006 11:43 AM
