Rear Suspension Arm Toque Spec
Hey, tried searching all over the net and here, but cant seem to find the FSM or torque spec for the rear suspension arm (part no. 48740F). Looking for the alignment bolt (4809) and hub side of the arm as well (90119-14079(2)).
Diargam:
http://lexus.sewellparts.com/oem-cat...400h-2006.html
Side note: this diagram is wrong, as the rearward arm doesnt have the adjustable arm, but cams on the subframe.
Thanks in advance!
Diargam:
Thanks in advance!
Mike,
Not every bolt there has a torque spec. I would simply tighten it pretty tight and be done with it. As long as the bolt doesn't come loose, it shouldn't effect alignment.
