08 RX-350 sun visors LEDS changeable??
http://www.vleds.com/bulb-type/festo...ight-bulb.html
I changed mine to led. I think I used these but not 100% sure. Definitely better than stock, just be careful not to scratch the plastic. Best to use a plastic tool.
everything is changeable. just depends on how much work you want to make for yourself. i doubt they are an easy replace. i suspect you will have to solder new ones in.
i did a similar project on my motorcycle, i removed the gauge cluster and replaced all the orange LED's with blue ones. involved desoldering the old ones off the circuit board and then soldering the new ones in.
http://drivers.lexus.com/t3Portal/do.../sec_06-01.pdf
There are certainly double ended LED replacements out there.
