Side mirror cover removal
Old 07-29-12, 08:53 AM
shikbas
shikbas's Avatar
Default Side mirror cover removal
Hi guys. I want to remove a mirror cover that I installed many years ago. It is like a painted plastic glued to the original cover by adhesive strips. Do you have any tips please? Thanks
Old 07-29-12, 12:03 PM
cartman57
cartman57's Avatar
A possible suggestion would be to take some GooGone in a hypodermic needle and apply it around the top seam, it might run down between the 2 points of contact, eventually the adhesive will loosen.
Mineral spirits might work too, don't use anything that'll chemically melt the plastic.
Old 07-29-12, 02:47 PM
mandyfig
mandyfig's Avatar
Post a pic or 2, will help us look at it.
Old 07-29-12, 02:57 PM
shikbas
shikbas's Avatar
Will do. Thanks
Old 07-31-12, 07:59 AM
shikbas
shikbas's Avatar
https://www.clublexus.com/forums/att...1&d=1343746406
this is the picture
Old 07-31-12, 08:05 AM
Rainbird
Rainbird's Avatar
What about heating the mirror cover with a hair dryer.
Old 07-31-12, 11:39 AM
LEXRX04
LEXRX04's Avatar
I would try heating it up slowly...watch the heat and pull gently...the adhesive should give
Old 08-01-12, 09:34 AM
shikbas
shikbas's Avatar
Thank you,will try that
Old 08-01-12, 01:57 PM
mandyfig
mandyfig's Avatar
Ooppss, sorry it will not be easy and you might be sorry what you will find...
Had the same happen on my CRV, stuck a mirror cover. Chrome faded, when I took them off, it actually scratched my side mirror. The fit was not perfect.
Old 08-01-12, 02:27 PM
sparks11
sparks11's Avatar
I removed ones similar from a ram a few days ago..I used a plastic putty knife and goof off.... spray some goof off
the best you can and then star to pry it careful...mine came alright no scratches or damged...my covers had adhesive strips for sure...another kind of glue I would not know if my method would work.
Old 08-01-12, 07:35 PM
glassmanj
glassmanj's Avatar
whatever you do completely tape off the rest of the casing so you don't scratch it. i agree with the hairdryer and heating just take it slow. once you get one tiny corner loose it should pull off slowly. and as you lift immediately use tape or cloth to protect exposed area so you don't harm it also. this is when you'll usually scratch surface.
Old 08-02-12, 06:48 AM
shikbas
shikbas's Avatar
Thumbs up
Thank you all
Old 08-03-12, 05:59 AM
LEXRX04
LEXRX04's Avatar
another thing that you could do is get some fishing line slip it thru the crack, and in a sawing motion go back and forth sliding thru it...this should help it separate from the adhesive.
LiquidG
06-09-16 07:56 AM
fozzyf
08-03-15 08:03 AM
symple84
10-06-14 07:26 AM
peverette
07-14-13 07:13 AM
Quick Reply: Side mirror cover removal
