Parking sensor doesn't work
I have bought Lexus RX350 with nevigation system. There isn't parking sensor switch. But there are sensor in front and back .
Could you help me for this problem. |
Originally Posted by wq394
(Post 7350607)
My RX350 model is 2008. My friend has RX350 2007 and it has parking sensor without any problem.
(Post 7351566)
http://drivers.lexus.com/t3Portal/do.../sec_08-01.pdf Perhaps the sensor(s) you are seeing are for the dynamic laser cruise control. http://drivers.lexus.com/t3Portal/do.../sec_02-04.pdf Different regions of the world have different packages available to them. It is possible that while it looks like you might have that feature it may not have been installed with the packages which came with your RX. Or, perhaps your RX was brought in from outside your region and from an area where this feature was not available. Here is an existing thread I easily found here on this topic: https://www.clublexus.com/forums/rx-...ng-assist.html You might try contacting Lexus corporate for your area or a local dealer to see if they can get you a printout for what was installed on your RX from the factory. If it says it was installed as part of a package you can work from there. http://www.lexus.com.sa/ http://www.lexus.com.sa/forms/dealer...chvalue=Jeddah They should be more than happy to work with you to determine the nature of the problem. Also, perhaps some of our buddies in Australia and other locations can chime in with additional information regarding what buttons or other indicators you might have to indicate if you have this feature or not. In Australia, for example, they have an interior motion detection feature not available in most areas. https://www.clublexus.com/forums/hyb...on-rx400h.html |
i have a fully loaded 09 and it does not have parking sensors... i don't think the 08's do either
Parking Sensors
wq394 is in Saudi Arabia.
Yes i am in saudi arabia but my car from US
(Post 7352885)
Where is your friend's RX from? Am going to guess it is from Europe or elsewhere. |
Originally Posted by RX330inFL
(Post 7352898)
Then I am pretty sure you do not have parking assist. Was not available here in the States until the model change for 2010.
Where is your friend's RX from? Am going to guess it is from Europe or elsewhere. got front / rear parking sensors :) |
'07 RX350 from EU dealer - has front parking sensors and backup camera
| All times are GMT -7. The time now is 03:00 AM. |
