Fuel Stabilizer
Old May 27, 2012 | 09:58 AM
martini84's Avatar
martini84
Default Fuel Stabilizer
I have an 2007 RX350 and I was wondering what is the best fuel stabilizer I can use for my car. My car needs premium gas also. Any suggestions please?
Happy Memorial day and thanks to our veterans!
Old May 27, 2012 | 10:26 AM
mandyfig's Avatar
mandyfig
I use Seafoam. Directly on gas tank (when near empty and then fill up). Works for me. Every 5K miles.
Old May 27, 2012 | 10:40 AM
Rainbird's Avatar
Rainbird
If you are driving normal mileage and using premium fuel you shouldn't need to add a fuel stabilizer. On the other hand if you are storing the vehicle or filing up infrequently a stabilizer would help.
Old May 27, 2012 | 10:50 AM
martini84's Avatar
martini84
cool, thank you both.
Old May 30, 2012 | 12:26 PM
kickin8's Avatar
kickin8
2IS/2RX/4RX
May I ask why you need a fuel stabilizer ?
Old May 30, 2012 | 04:09 PM
Grumpa72's Avatar
Grumpa72
I have an old Corvette that is stored at least four months out of the year and I sometimes (intentionally) forget to put fuel stabilizer in it when I store it for the winter. The car ALWAYS starts and runs just fine. If you are driving your car on a normal basis there isn't ANY logical reason to buy and use fuel stabilizer. Someone is trying to sell you something you don't need, imo. Sort of like Marvel Mystery Oil that someone on a Corvette forum said was good for adding to engine oil after an engine rebuild as well as put into a gas tank! Wow! It works as both a lubricant and oils agent?
Forget about oil and fuel additives on a conventionally driven car, imo.
Old May 30, 2012 | 11:30 PM
pauljcl's Avatar
pauljcl
Originally Posted by Grumpa72
I have an old Corvette that is stored at least four months out of the year and I sometimes (intentionally) forget to put fuel stabilizer in it when I store it for the winter. The car ALWAYS starts and runs just fine. If you are driving your car on a normal basis there isn't ANY logical reason to buy and use fuel stabilizer. Someone is trying to sell you something you don't need, imo. Sort of like Marvel Mystery Oil that someone on a Corvette forum said was good for adding to engine oil after an engine rebuild as well as put into a gas tank! Wow! It works as both a lubricant and oils agent.
+1. I store my BMW for four to five months a year, and have never used fuel stabilizer. Never had a problem.
Old May 31, 2012 | 07:25 AM
neilaz's Avatar
neilaz
I use a stabilizer for any fuel being stored for more than a month due to the ethanol. If you don't have ethanol it is not as likely to absorb water and then have that water fall out of suspension.
Old May 31, 2012 | 07:45 AM
tfischer's Avatar
tfischer
25 Year Member
Fuel stabilizers are pretty inexpensive, and I doubt that there is much difference between the brands. It is not something to be added to the car on a regular basis, only when leaving a car unattended for several months or more, such as storing a convertible over the winter, or leaving a car in Florida during the summer. Considering the small cost, it's not a bad idea in those circumstances. I don't drive my convertible much during the 3 or 4 winter months here in Ohio, and I usually add stabilizer just for the heck of it.
Old May 31, 2012 | 08:41 AM
pauljcl's Avatar
pauljcl
Before storage, I fill up the tank as completely as possible. This is to prevent fuel contact with air. Why would ethanol's absorbed water 'fall out of suspension' when ethanol (i.e. alcohol) is known to absorb humidity/water rather than release it?
Old Jun 1, 2012 | 07:09 AM
neilaz's Avatar
neilaz
Maybe this will help: Ethanol is a hygroscopic liquid, meaning that is readily attaches to water. It it also fully miscible (mixable) with water. In very small amounts this is not a problem. But when the saturation exceeds a specific amount is becomes a major problem called Phase Separation. The amount of water Ethanol can safely absorb is dependent on the temperature of the fuel. At 70°F it is .5% (.005) of the volume. If it exceeds this amount the Ethanol and water will fall from suspension and sink to the bottom of the tank forming an Ethanol /Water layer that can produce acids and cause major engine failures. Look around and you will find a lot of info on this.
Old Jun 1, 2012 | 12:25 PM
pauljcl's Avatar
pauljcl
With a full tank, there is little chance that the saturation point will be reached, other than if it was reached previously, which is most unlikely since problems would have occurred.
Old Jun 1, 2012 | 10:02 PM
willyb0b's Avatar
willyb0b
STA-BIL with a fresh tank of gas. You can go 1-2 years depending on how much you use. Directions are easy to follow on how much to use and the stuff is pretty cheap.
Old Jun 2, 2012 | 04:01 AM
jfelbab's Avatar
jfelbab
FWIW, here is a link to a $2.00 rebate on STA-BIL good until the end of the year.
http://www.goldeagle.com/UserFiles/file/STA-BIL%20files/S_STABIL%20Marine$2Rebate3_11.pdf
Old Jun 2, 2012 | 11:13 AM
willyb0b's Avatar
willyb0b
I'm printing one out now! thanks!
