2004 RX330 Air Suspension issue
Hi HtownBlue looking to convert my rx300 o4 to spring/shock from air suspension. Would you know supplier/part numbers etc. Noticed you done yours but want to make sure I order right starts. Hope you can help
Most any standard fitting strut for the make and model year of your RX will work. The mount points are the same. You will have to remove the switch from the pump in rear otherwise your pump will run perpetually.
I have a 2004 with air suspension, front passenger suspension is about an inch higher compare to the other 3. It doesn't matter what setting its on, L,N or H, it's still and inch higher. Dealer recalibrated the ride height and it did not help. I tried searching and can't find answers. Pls. help.
FatherTo1
Jul 22, 2017 08:37 AM
jasone36
Oct 3, 2015 09:56 AM
