TSB transmission re-flash
Old Sep 27, 2010 | 09:33 AM
lexus114's Avatar
lexus114
Originally Posted by mandyfig
Hopefully your tranny will survive it. Otherwise they might change it. All replacement trannies are rebuilt which does not mean inferior. Good luck to you.
thanx, i think i`m going to need it.
Old Oct 2, 2010 | 09:04 PM
khilgers's Avatar
khilgers
well I brought the car in on tuesday, they had it for about an our and basically re-set the ECM and whatever else is involved with the TSB. The service guy told me that I should drive the car harder than normal for about a week since they have had some come back where the re-flash didn't take effect. To be totally honest it almost seems like the problem is worse AFTER bringing it into the dealership. In the 2 months I have owned it I have only noticed the tranny shifting issues about 3-4 times.
Since AFTER the "fix" it has done it about 4-5 times THIS WEEK. Under hard acceleration the tranny shifts fine, but under soft acceleration it seems to only bog between the 2-3 gear shift.
Any clues, should I bring it back to the dealership, is there anything else they can really do about the problem without it costing me an arm and a leg?
Old Oct 4, 2010 | 11:17 AM
ohiois350's Avatar
ohiois350
yeah it happen same thing with my gf 04 rx330 too after I took the truck in for the tranny ecu upgrade, and it worse than before, it happen between the 2nd and 3rd gear, I will take the truck back this weds for dealer to check
Old Oct 4, 2010 | 11:42 AM
lexus114's Avatar
lexus114
https://www.clublexus.com/forums/rx-...59-update.html
Old Oct 7, 2010 | 03:07 PM
MrBruin09's Avatar
MrBruin09
You should take your battery out for 30 minutes so everything in the car resets...and drive the hard for 2 weeks so your car gets used to your new driving habit.
My service adviser told me this, instead of paying to have my ecu-flashed..
Old Oct 8, 2010 | 06:24 AM
lexus114's Avatar
lexus114
That isnt going to do it. When they re-flash the ecm,their adding new data to the computer. (up dated data) I cleared the ecm before this a few times,and it was no real help.I did notice that it shifted better (before) on the 87-89 octane fuel.
Vols4life
Jun 13, 2020 09:24 PM
tomsawyer
Feb 27, 2016 09:48 PM
ericg
Feb 28, 2009 04:42 PM
GFC350
Nov 29, 2007 10:35 AM
amf1932
Nov 17, 2003 12:57 PM
