Passenger Side Mirror Suddenly Changed Color
Old May 10, 2010 | 09:06 PM
LBCDan's Avatar
LBCDan
Default Passenger Side Mirror Suddenly Changed Color
The passenger side rear view mirror on my '04 RX has suddenly changed color to a bronze tint. Has anyone had this happen to their vehicle? Any thoughts?
Old May 11, 2010 | 03:44 AM
Fivewilds's Avatar
Fivewilds
I have on 04 that has done the same thing about six months ago. I have no idea why.
Old May 11, 2010 | 05:41 AM
mandyfig's Avatar
mandyfig
If you are still under warranty, they will replace it. If you are call your service advisor.
Old Aug 1, 2023 | 11:36 AM
wdkwild's Avatar
wdkwild
7th Gear
Default Bronze color
Originally Posted by mandyfig
If you are still under warranty, they will repalce it. If you are call your service advisor.
No help here tried to delete
Old Aug 1, 2023 | 11:57 AM
Felix's Avatar
Felix
Originally Posted by wdkwild
so what if you're not under warranty is there any fix?
I'd replace the mirror glass, if it bothers you.....
Old Aug 1, 2023 | 01:36 PM
wdkwild's Avatar
wdkwild
7th Gear
Not what I asked Good job overstating the OBVIOUS!
Old Aug 1, 2023 | 02:36 PM
MattRX's Avatar
MattRX
Well, REPLACE the mirror if it bothers you, which it clearly is doing. Be prepared to replace it soon again though if it's used, as they're all on borrowed time.
Old Aug 4, 2023 | 02:06 AM
cfh13427's Avatar
cfh13427
Hi, it happened on my '05 RX330, I was told that it was the fluid from the Auto Dimming leaking onto the mirrored glass.
I replaced it with a used OE mirror glass, and it did the same thing 6 months later.
I bought a precut stick-on mirror glass and put it on over the old mirror glass.
It Looks and Works Great!
It just Doesn't Auto-Dim, No Big Deal, and I Don't have to Worry about it happening again!
Old Aug 6, 2023 | 06:55 AM
dpleticha's Avatar
dpleticha
Default From Amazon
My driver’s side mirror did the same thing when I broke it TWICE! However I don’t believe it’s for auto dimming as the replacement assembly (see below) says they are heated mirrors and the oil is for better heat transfer. Any who, here are some parts you can order on Amazon if you like:
New Replacement Mirror Glass with FULL SIZE ADHESIVE for 2004-2009 LEXUS RX330 RX350 RX400H Passenger Side View Right RH https://a.co/d/cmdMjRg
Worked great as long as you line it up correctly.
They also have replacement mirrors assembled with the heat element for four times the cost.
Brock Replacement Passengers Power Side View Mirror Heated and Memory Compatible with 04-06 RX 330 07-09 RX 350 06-08 RX 400h SUV 879100E011C0 https://a.co/d/4DiWFzs
i don’t know if anyone has had the paint literally fly off the housing but my RX400h had both mirrors do that and it was almost impossible to get paint to stick to them! Had to prime it several times before it did! Just an FYI…
Old Aug 6, 2023 | 07:27 PM
cfh13427's Avatar
cfh13427
FYI- I put a Stick On Mirror Glass over the Crapped Out Auto Dimming Glass on my 2005 RX330 Side View Mirror and it still Defrosts the Stick On Mirror!
The heating element in the old mirror glass is still Good and the Heat goes thru the Stick on Mirror, and keeps it Defrosted! and that's Great!
Ezra
Hawaii and Guam
Jun 24, 2016 07:50 PM
2008GS
May 3, 2016 12:43 PM
