RX330 differential lockup
Old Apr 14, 2010 | 07:23 AM
bacchus's Avatar
bacchus
Angry RX330 differential lockup
While driving at about 65 mph, my differential seized up causing complete lack of control. Spun a few times ending up on shoulder of highway. Happened around 11:30 at night. If it had happened during daytime traffic the
result would likely have been catastrophic.
Does anyone know if this happens frequently?
The shop my car was towed to said they had three other instances of the same thing happening with this model.
Old Apr 14, 2010 | 07:56 AM
phlfly's Avatar
phlfly
WOW. it's a very dangerous. Call to Toyota let them know.
Did you have oil serviced right for transfer case, I meant level?
Old Apr 14, 2010 | 01:16 PM
georgie39's Avatar
georgie39
Default Differential Lockup
Boy!!!
This is scary.....Did the "diff" give you any warning? Like maybe noise or a surging as you were driving that would indicate that there was perhaps a seriously chipped tooth on one of the gears or that the gears were not meshing correctly?
I'm with the previous responder, Was there the proper level and amount of lube in the differential?
Old Apr 15, 2010 | 02:48 PM
bacchus's Avatar
bacchus
It vibrated about a second before failure. I thought I was getting a flat. Then all hell broke loose.
Called Lexus national, being diagnosed now.
Will let you know.
Old Apr 15, 2010 | 03:14 PM
Nad1370's Avatar
Nad1370
Will let you know.
Good thing that no one was injured.
Was it the front diff or the rear?
Did you had any work done recently prior to the incident?
Old Apr 15, 2010 | 03:18 PM
Rainbird's Avatar
Rainbird
How many miles are on this car? You should also file a safety defect report with the National Highway Traffic Safety Administration. Link below:
http://www-odi.nhtsa.dot.gov/ivoq/
Sevenfold
Sep 23, 2016 12:23 PM
xtra
Oct 22, 2013 04:46 AM
afx588
Mar 1, 2013 01:04 PM
sc310hp
Jun 5, 2008 04:56 AM
Cosm
Nov 9, 2002 06:58 PM
