RX330 error p0441 p0556 p0455
Old Mar 14, 2010 | 03:08 PM
smokey007's Avatar
smokey007
Default RX330 error p0441 p0556 p0455
Hello, I just purchased this 2005 RX330 from a Dealership. Only 31k Miles on it. I hope I did not buy a lemmon. Drove the vehicle under 100 miles and CEL and VSC light came on. Car runs fine but I ran OBD test and got the following error codes
P0441 Evap Emission COntrol System Purge Flow Fault,
P0446 Evap Emission Control System Vent Circulation Malfunction
P0455 Control System Leak
I did check this board and did not see any problems with the gas cap, althought it did not hiss when I took it off, and Air flow hoses seem to be tight. Any suggestions ?
Old Mar 14, 2010 | 04:47 PM
Lexmex's Avatar
Lexmex
Welcome to the Club.
Keep in mind your vehicle is still under the 8 year/80K Federal Emissions Warranty and those things should come under that.
Generally those faults are related to one of the following: gas cap issue (not tight enough or bad), a hosing (leak usually) on the of the engine and extending to the back to the charcoal canister (black box underneath the rear of the vehicle).
Old Mar 15, 2010 | 07:05 AM
mandyfig's Avatar
mandyfig
Take it in, lexmex is right. Do not sweat it, it is under warranty.
Old Mar 15, 2010 | 08:43 AM
smokey007's Avatar
smokey007
After taking it into the dealership, they ran test on it. It turns out to be a bad gas cap rubber gasket, which they say caused the errors. They replaced the gas cap, and tested the Evap system, which then showed no leaks. I drove the vehicle 20 miles after testing and so far its OK Thanks all !!
kb89
Sep 26, 2018 01:32 PM
linkman
GX - 1st Gen (2003-2009)
Feb 6, 2012 05:10 AM
erichard78
RX - 1st Gen (1999-2003)
Nov 27, 2011 03:02 PM
DaveN
Jul 20, 2010 08:11 PM
