Rear Wiper
Old Feb 23, 2010 | 10:45 AM
kiwi's Avatar
kiwi
Default Rear Wiper
i have tried replacing my rear wiper blade (refill) to no avail, i cant get complete coverage on the rear glass, any suggestions? (no warranty, 2004)
Old Feb 23, 2010 | 01:34 PM
rcy's Avatar
rcy
Replace the entire blade, not just the insert. Possibly the blade is worn/damaged? No idea what it costs at the dealership, but there are aftermarket available. Do a search here or lexusownersclub - there was a recent DIY posted regarding this. Just did it myself recently.
Old Feb 23, 2010 | 01:46 PM
KeysRx300's Avatar
KeysRx300
Default Rear Wiper Blade
Are you trying to change the rear blade because its bad? Or are your trying to put on a bigger blade to get more coverage?
Old Feb 23, 2010 | 03:03 PM
kiwi's Avatar
kiwi
i am happy with the factory coverage, i am simply looking to replace OEM.
the original problem was that the blase was wearing out, after replacing with oem insert, it no longer touched all of the glass
Old Feb 23, 2010 | 04:43 PM
jekyll's Avatar
jekyll
Did you put the 2 metal pieces back in with refill? They keep the rubber piece straight and in place.
Old Feb 23, 2010 | 06:20 PM
KeysRx300's Avatar
KeysRx300
Default Rear Blade
So you want to just replace the old blade with a new one?
You just buy the correct length. Pull the cover off of the end. Where it connects to the motor. The whole assembly pops up. Pull out the old one. Install the new one.
Old Feb 24, 2010 | 03:49 PM
kiwi's Avatar
kiwi
yes i reinstalled the metal strips,
and second i know how to change it, i have., the issue is that it does not remedy the problem, there is still an area which does not get wiped.
Old Feb 24, 2010 | 05:18 PM
kitlz's Avatar
kitlz
No, I don't play soccer!
kiwi, there is a TSB on this. I'm not sure what the fix is since I never did it. You said you're out of warranty so that doesn't help But that annoying little area it doesn't clear can be annoying. I would pick up the wiper and drop it on to the glass. Sometimes it worked, sometimes it didn't. I noticed it happened more the first few swipes and got better. Maybe a newer wiper arm would help Good luck.
Old Feb 25, 2010 | 06:43 AM
xfirechief's Avatar
xfirechief
I had this problem when we had our '04. Lexus replaced the whole arm & blade at NO CHARGE. It was still under warranty then. They said Lexus was having an issue with the spring tension if I remember correctly.
Old Feb 25, 2010 | 09:57 AM
mandyfig's Avatar
mandyfig
Has to be the spring. Change the spring.
akfd
GX - 2nd Gen (2010-2023)
Jan 4, 2019 05:10 PM
jeff618
Hybrid Technology
Jan 25, 2012 12:17 PM
acurazinee
GX - 1st Gen (2003-2009)
Aug 4, 2009 11:03 AM
Capirato
12
Dec 10, 2007 10:35 AM
wilnis
Sep 15, 2006 06:47 PM
