recalls
Old Feb 1, 2010 | 06:31 PM
sirCharles's Avatar
sirCharles
I 'd take it to the dealer and have them decide. They have to right this situation until...
Old Feb 1, 2010 | 07:20 PM
RsSharKy's Avatar
RsSharKy
Originally Posted by biff44
The gas pedal in my RX looks very different from the design used in the avalon, so I guess we are ok. The lower one in this picture is the one being recalled:
http://www.thetruthaboutcars.com/exc...-recalled-too/
that web page mentioned something about "denso" pedals
"But according to our sources, the Denso unit will likely be recalled too. "
i hope that is not going to happen
didn't someone mention that RXs are using Denso's
Old Feb 2, 2010 | 06:53 AM
mmlex1987's Avatar
mmlex1987
From what I have reviewed and read, I think RX's are not affected at all.
Old Feb 2, 2010 | 01:23 PM
joako's Avatar
joako
Originally Posted by mandyfig
I believe the issue is more electronic than mechanical. Maybe it so happens that Tacoma and the RX have a different logic design. Just speculation.
Actually the issue has to do with the accelerator pedal becoming physically stuck. The solution is adding a spacer (we are talking milimeters here) so the pedal can not be fully depressed to the point it becomes jammed. The same thing with acceleration would happen on a throttle cable car.
So if there is any doubt, simply do not floor the pedal up to the point the kickdown is activated... I can't recall the last time I needed to use that anyways, just be calm and relaxed when driving, you can't feel the road in a Lexus anyways.
Old Feb 3, 2010 | 04:53 AM
biff44's Avatar
biff44
Are you sure. I heard that the problem was that the plastic body of the accelerator racks, and that makes the steel pivot bind in the brass bushing. I thought the solution was more like a bracket that supports the whole plastic body.
Old Feb 4, 2010 | 02:40 AM
biff44's Avatar
biff44
http://pressroom.toyota.com/pr/tms/t...ve-153311.aspx
Apparently we are both wrong. The fix involves slipping a metal plate inside of the pedal housing, to defeat a "friction plate" that they deliberately put inside of the pedal to give it the right "feel".
Old Feb 5, 2010 | 07:37 AM
biff44's Avatar
biff44
as I feared, saw on the news this morning that there will be lexus recalls too. Hope its not the RX!
Old Feb 5, 2010 | 08:24 AM
Joeb427's Avatar
Joeb427
All Lexus vehicles should have the reflash of no or very little throttle cutoff when brake is applied like the ES is having done.
I don't know why Lexus did away with this safely imput that German and other manufacturers have had in their vehicles.
Old Feb 9, 2010 | 07:12 AM
LexsInTex's Avatar
LexsInTex
The news this morning said the Lexus recall would be for the 2010 HS Hybrid.
Old Feb 10, 2010 | 08:54 AM
RsSharKy's Avatar
RsSharKy
Well, here is something that news didn't mention
my co-worker' es350 is being recalled
he got a letter from Lexus couple days ago
it's regarding the sticky gas padle & also some kind of switch
Old Feb 10, 2010 | 09:11 AM
jfelbab's Avatar
jfelbab
http://pressroom.toyota.com/pr/tms/c...ng-153495.aspx
Old Feb 14, 2010 | 10:18 PM
mackinta's Avatar
mackinta
The unexplained accident in San Diego involving a Lexus ES and recorded on a 911 tape has not been addressed by Toyota. Everyone driving a Toyota product should practice (and with anyone who drives their cars) how to put the transmission into neutral while driving and THEN turn the ignition to ACC (but do not remove key because the steering wheel will lock). It is something to think about before faced with the situation and the feelings of panic. The ES was driven by a police officer (expert driver) who was unable to overwhelm the car's power with the transmission engaged with the brake.
Anipilot
NX - 1st Gen (2015-2021)
12
Jan 20, 2017 07:07 AM
Tom558
RX - 3rd Gen (2010-2015)
31
Nov 12, 2013 08:49 AM
RXSF
Jun 4, 2009 04:25 PM
