Where is the amplifier? 2006 RX330
2006 RX330, loss of volume I checked the fuses they are ok. I thought the amplifier might be under the drivers side rear seat, but I can't get at it. Any suggestions or is the amplifer someplace else. Thanks, amy
Amy, are you out of warranty because I'd have the dealer check it for you. The amp is under the rear seat. I found this description in another thread. I believe the best way to get at it is to remove the plastic cargo tray closest to the rear seats. Good luck.
https://www.clublexus.com/forums/rx-...330-rx350.html
coolhand
Jan 22, 2007 09:08 AM
