*MERGED THREADS*: Headlight Condensation includes DIY instructions (See Post #19)
#181
That is quite possible. I do not recall at which side I was looking for it now. However with that in mind, how much good does that gasket actually do at sealing water out from below? It's not like we are traversing deep streams and run the risk of water getting so high, that it ruins the ballast from below. From my understanding, and personal experience, my was ruined from water getting to it from above, through a poorly designed Lexus headlight seal.
On a side note, does anyone know what the part number is for the small black round clips that hold the vertical black plastic piece which is located towards the center of the vehicle beside either headlight? I have looked at multiple parts diagrams on Sewell's site, and cannot find this area, or part anywhere. Sorry, I should have attached a picture and can do this later if need be.
Thanks
Thanks
#182
Headlight condensation
I'm new to the Lexus forums. I just purchased a 2005 RX330, 65K. The driver's side headlight has a lot of condensation in it & the projector light is not working. Replaced the bulb, but that did not fix the issue. The Cadillac dealer that I bought it from said that the whole assembly needs to be replaced. Is that the usual fix?
#183
Probably the ballast. Are they going to pay for it? If so a new headlight assembly and ballast would be nice. If you are stuck with it you might be able to replace the ballast and reseal the headlight.
#185
The dealer is going to replace it because I can't get an inspection sticker (safety issue). They have to paint the fender too (masking tape removed some of the paint clear coat).
#186
Welcome to CL. Use the saerch on headlamp condensation, tons of info. Good luck.
#188
#189
The ballast can be replaced separately. The ballast is located on the underside of the headlight housing behind a plastic cover. From my understanding, there are four screws that hold the cover on, and once the cover is removed, it is easy to replace the ballast. You can buy the ballast on ebay for about $150. If you choose to just replace the ballast, I strongly recommend that you re-seal the light. mandyfig did a DIY a while back on how to re-seal the headlight (see link).
https://www.clublexus.com/forums/rx-...densation.html
#190
Yes better be safe than sorry. Go for it.
#195
Hi All, I also have this issue. The real stopping point for me is the cost of the new assembly. The dealer here in california quoted $1900. WTF..
I was hoping to just replace the ballast and do the DIY. For those who have done the DIY, is it terribly hard for those who don't work on cars all the time?
Thanks!
Thanks!
