Adding Aux Input
Old Apr 4, 2007 | 10:12 AM
biff44's Avatar
biff44
Dice unit, huh? Which radio and year of RX do you have?
Old Apr 4, 2007 | 10:14 AM
biff44's Avatar
biff44
Originally Posted by maccpl
I have to admit an Aux Input on the front would have been so much nicer, but you wouldn't get your IPod charged and you would not have the control that the Vais and Grom units provide.
Cheers,
JR
The multipin connector on the bottom of the IPOD has both audio outputs and a DC charge input. You could make up a single cable that would work with the aux input unit AND charge at the same time.
Old Apr 4, 2007 | 10:17 AM
biff44's Avatar
biff44
Such as this thing. Gets dc from a cig outlet, and has a 3.5 mm audio output connector at the end.
http://catalog.belkin.com/IWCatProdu...uct_Id=193794#
Old Apr 4, 2007 | 10:20 AM
rguilfoyle's Avatar
rguilfoyle
I have the standard internal 6cd changer head unit (Type-B) - no nav no Mark Levinson. It's a 2004.
Here's a link to the Dice unit:
http://www.diceelectronics.com/ipod_integration.htm
Old Apr 4, 2007 | 10:37 AM
rguilfoyle's Avatar
rguilfoyle
That will work, but the sound quality is notoriously bad on the fm transmitter units.
Old Apr 5, 2007 | 03:37 AM
biff44's Avatar
biff44
That is obviously NOT an fm transmitter. It has a coax output (which means a cable connection).
Old Apr 5, 2007 | 04:26 AM
CK6Speed's Avatar
CK6Speed
I think it is by reading this definision in the description
lets you play your iPod through your car stereo or other audio equipment when using a Belkin TuneCast Mobile FM Transmitteror Cassette Adapter.
Old Apr 5, 2007 | 04:27 AM
CK6Speed's Avatar
CK6Speed
I have the Dice unit. It plugs into the external CD changer plug on the back of the head unit. The ebay unit looks like it works the same. On mine the cd changer in the head unit shows up as CD on the display and the Dice unit is CD1. Both are operational. Pressing the "Disc" button toggles between them.
That is good to know the indash CD changer headunit actually has an external CD changer port. When I removed mine I never bothered to look
Old Apr 5, 2007 | 04:55 AM
biff44's Avatar
biff44
What Belkin is inarticulately trying to say is this: Here is a cable that can be plugged into the cig. lighter to DC power your Ipod. In addition, there is a tiny coaxial connector in the cig. lighter plug that has the left and right audio outputs, amplified. If you wish, you can hook up an FM modulator to this coaxial connector to wirelessly transmit to your FM receiver, OR you can use a hardwired connection between the Cig. plug and your aux. input".
I should have been in marketing!
Old Apr 5, 2007 | 09:53 AM
rguilfoyle's Avatar
rguilfoyle
No, not an FM transmitter itself, but it's either use a transmitter or use a cassette adapter since we don't have a factory aux input. I didn't like either choice.
Old Apr 6, 2007 | 01:00 AM
AM1's Avatar
AM1
CL Folding 100,000
i saw the dice unit, but then i was afraid of some features not working, thats why i went with the vaistech unit
Old Apr 6, 2007 | 03:51 AM
rguilfoyle's Avatar
rguilfoyle
So far it works as advertised. The unit on ebay seems to have even more features and you can choose either ipod integration or just an aux input for a reasonable price. That looks like it might be a good option for drray to try. Should be able to return it if it doesn't work right.
Old Apr 6, 2007 | 08:11 AM
RC_Av8r's Avatar
RC_Av8r
Both the Dice unit and the one on E-Bay say they are NOT supported on the 2007 RX 350. I believe that is the car that drray has.
When you say it works is that on the 07 350? I'm asking because I drive the 350 as well.
Thanks,
Dave
Old Apr 6, 2007 | 12:00 PM
SilverLady's Avatar
SilverLady
Question
How different is the RX 350 sound system from the ones on the IS350 or ES350 that come with the aux ports?
If the basic units are exactly the same (and I can't imagine why they would design one that different for this one model), it is possible that the unit itself supports a standard aux port, but Lexus for some reason decided they had no room to run a wire from the unit to either the dash or storage box. (or some other wierd marketing decision as to why they crippled it).
If that is true, it should not be a big deal to run that wire! Anybody know???
Old Apr 6, 2007 | 12:19 PM
biff44's Avatar
biff44
Tha is an interesting point! I would be willing to research it a little if anyone knew the part number and manufacturer of the radio itself.
