Backup Lights - Brighter Bulbs?
Old Jun 25, 2007 | 09:01 AM
  #31
RiNsE_OuT's Avatar
RiNsE_OuT
I replaced mine with PIAA H-224 Xtreme White 921 bulbs. They match to HID pretty well, though not really sure if the are brighter (i.e. provide better rearward visibility).
Here's a pic:
Attached Thumbnails Backup Lights - Brighter Bulbs?-rx350_reverse_lights-3.jpg
Old Jun 25, 2007 | 12:35 PM
  #32
The G Man's Avatar
The G Man
They look brigher, but its hard to tell from a picture with tinted bulbs.
Old Jun 25, 2007 | 12:57 PM
  #33
mandyfig's Avatar
mandyfig
Is this an outright replacement? Just pull and replace?
Old Jun 25, 2007 | 01:00 PM
  #34
The G Man's Avatar
The G Man
The PIAA extreme white bulbs are direct replacement.
Old Jun 25, 2007 | 01:37 PM
  #35
mandyfig's Avatar
mandyfig
I should try this. I will visit my Advance Auto store tonight. Who has the DIY for this? It will involve taking apart the rear hatch, right?
Old Jun 25, 2007 | 01:38 PM
  #36
mandyfig's Avatar
mandyfig
Anybody's taken pics on this DIY? If not, I will. I need to check my Manual.
Old Jun 25, 2007 | 01:43 PM
  #37
mandyfig's Avatar
mandyfig
Originally Posted by ccds
I have been monitoring the back up lights for the past month and have not
had any sign of over heating. I am very focused on not leaving the car
in reverse for an extended period of time. I think if the lights were left on
for a long time it could damage the plastic housing or the plastic lens.
I am the only one that drives this vehicle so I know that the longest reverse
time is only about 25 sec. that I back out of the drive way.
I will continue to monitor the heat issue and see what the result is and post
the results here a bit later.
If anyone has questions I do have pictures of the modification and the bulbs
and I would be glad to share that info.
you can email me at ccds22@gmail.com
Sent you an email request.
Mandy
Old Jun 25, 2007 | 01:45 PM
  #38
mandyfig's Avatar
mandyfig
ccds, ok, I read the rest of the post, thanks anyway. Mandy
Old Jun 25, 2007 | 02:05 PM
  #39
RiNsE_OuT's Avatar
RiNsE_OuT
Sorry, I did not take pictures of the procedure. But I believe if you search the lighting forum on replacing the license plate lights, there are instructions for accessing the bulbs located in the hatch. It does involve pulling the two panels off the inside. Just pull down on them (starting from one corner) and they will come out. It will sound like you are breaking something, but that's just the clips that secure the panels popping out. Once the panels are off, you'll see the wires going to the bulb housings (license plate, break lights, reverse lights, etc) The owner's manual actually has a pretty decent diagram that shows which bulb is the reverse light and how to remove it. When replacing the panels, you will need to make sure the clips are lined up with the holes or you may risk breaking or bending one of the clips. (putting the panels back was harder then removing). The entire process took no more than 5 minutes.
BTW, I just posted a bunch of pics in the lighting forum of other replacement lights I've done on my RX350 if you're interested (I went a little crazy with the light upgrades).
Old Jun 25, 2007 | 04:59 PM
  #40
mandyfig's Avatar
mandyfig
Great, thanks, I will check on the light forum.
Old Jun 25, 2007 | 05:06 PM
  #41
sama's Avatar
sama
Here are the instructions, Caution: I did not try it, DIY at your own risk.
Old Jun 25, 2007 | 05:13 PM
  #42
mandyfig's Avatar
mandyfig
Fantastic! I wish I has this help when I tried to de-bug my stop light.
Old Jun 25, 2007 | 10:55 PM
  #43
AM1's Avatar
AM1
CL Folding 100,000
i should probably try doing that since my taillights are smoked black.
Old Jun 26, 2007 | 06:25 AM
  #44
mandyfig's Avatar
mandyfig
Show us pics, how did you do it? Ohhh, the film....yes I remember.
Old Mar 17, 2009 | 04:27 PM
  #45
RsSharKy's Avatar
RsSharKy
sorry to bring this old topic "alive" again.
i recently bought a new RX and having trouble seeing at night by using that backup camera
i got myself some PIAA also but they just not as bright as "Rinse Out's" are!!
for some reason i only see the bottom half of the backup light housing get reflection
the top half just don't get any lights reflect from the lower half
is there something wrong with mine or all of us are like that?
